tpi to carb is it worth it
Old Jun 21, 2010 | 09:27 AM
smallblockcrazy's Avatar
i have a 89 camaro rs with a 305 iwas wondering if it was really worth switching it to carburation
Old Jun 21, 2010 | 11:54 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: tpi to carb is it worth it
NO!!
keep the tpi. You will not benefit swapping to a carb.
Old Jun 21, 2010 | 12:57 PM
J.Prock's Avatar
I did the TPI to carb swap and hated it. Lost so much torque and was way less unreliabe then TPI so now I get the honor of putting the old TPI engine back in and Reqire the whole motor and everything
Old Jun 21, 2010 | 01:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
An '89 Camaro RS is TBI, unless someone went to the trouble to convert it over to TPI.
Old Jun 21, 2010 | 01:52 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
nope
Old Jun 21, 2010 | 02:02 PM
3rdgenmaro's Avatar
Car: 88 IROC
I was thinking that, but I wasnt for sure, so I didnt mention it.
Either way, there is no benefit. Keep the car fuel injected.
Old Jun 21, 2010 | 11:54 PM
brianfish18's Avatar
Im in the same boat...just about to pull my 305 tbi and replace it with a 350 out of early 90's truck. Isnt it a lot easier and cheaper just to go carb'd, rather than messing with the wiring harness, ecm etc etc...?
Old Jun 22, 2010 | 07:18 AM
3rdgenmaro's Avatar
Car: 88 IROC
Are you going with a stock rebuild? if you are, then you dont have to swap anything. A stock 350 will run just fine with the 305 tbi. I bought a 90RS with the 305 tbi a few years back. Motor had been run without oil. I had a 350 block that I rebuilt, reused the 305 heads, rv cam, 305 tbi unit. Car ran great. Was not a powerhouse, it wasnt built for that purpose, but it ran better then a stock 305 and it was a good driving car.
Old Jun 22, 2010 | 07:23 AM
3rdgenmaro's Avatar
Car: 88 IROC
double post.
sorry
Old Jun 22, 2010 | 10:02 PM
I made a mistake my camaro is TBI . I bought the car not running these people tried to fix it themselves so the distributor wasnt bolted in and countless things were lose so I got under it to see where an oil leak was coming from and I seen #1 and#3 cylinders connecting rod shot out of the oil pan. I wanted a bigger moter anyways. I am thinking abot a 350,383/or if it would fit a 427 or a 454
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
