Intake Manifold Question...
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
How does the factory-original L-69 intake manifold compare with the Edelbrock Performer (the regular Performer, NOT the "RPM")? Is there any significant performance difference between the two?...
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Intake Manifolf Question...
Not sure, but I am wanting to say that all small blocks had the same 4bbl intake. This being the case, I imagine anything aftermarket is better than stock. We had an 82 z28 with the standard performance 305 4bbl in it and we changed the intake out for a Holley Street Dominator intake and had excellent erpformance out of it coupled with a Holley Street Avenger carb.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The factory aluminum manifold is more or less equal to the base Performer intake.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not a lot of difference to be had between the stock manifold and the Performer. The Performer RPM is a bit of an upgrade.
Car: 85 trans am
Engine: 5.7 goodwrench edelbrock everything
Transmission: t-5 stage 2 clutch
Axle/Gears: 3.27 posi
there are differences in stock manifolds for instance the l-69 motor had the aluminum intake from the factory not every v8 had one most were cast ,and to answer ur compare ? yes the edelbrock performer will add a signifficant amout of low end torqe to the 305 over the stocker if ur goin for emissions legal u need a performer egr part 3701 if no emissions part2101
Car: 85 trans am
btw dont go with the rpm u will lose much low end power those manifolds are for 1500-6500 rpm band plus if u have a stock hood u will possibly end up with clearence issues
The "RPM" is not an option. I was interested strictly in any comparison between the stock L-69 4V aluminum intake, and the standard Edelbrock "Performer" manifold. They don't appear to be all that different, but I know that appearances don't always tell the whole story...
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
