can i use my stock carb.
Old Aug 15, 2010 | 12:26 AM
87firebird305V8's Avatar
Car: 87 firebird
Engine: carbed 305
I bought a truck engine 305 for my firebird. so i was planning on removing all of my AIR shat. money is very tight for my limited wages. i was told that i could fun my stock carb with out any of the wireing hooked up. im running a hei distributor. so can i just hook up the fuel likes and a few vacume lines for it to work or not, and where can i buy new fuel lines from the carb to the mechanical fuel pump
Old Aug 15, 2010 | 12:47 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Unless this is a Canadian car, you need to run a factory-type distributor with the factory computer carb. You can remove some things like the A.I.R. without it affecting the way the engine runs, but of course legally you can't remove any of that stuff.
I don't know if you can get a new fuel pump to carb hard line. Summit has a flexible line kit. I have a good used hard line that is available if you're interested.
Old Aug 15, 2010 | 08:23 PM
Car: 87 firebird
Engine: carbed 305
Re: can i use my stock carb.
what things do i need to run the stock distributor. i was planning on running W/O the computor but if its just a few plug ins, i will, and does it make a difference between hard and soft lines
Old Aug 15, 2010 | 09:33 PM
DoubleV's Avatar
If you want to run the stock distributor, then you must also run the stock carb which means you will be running on the computer. If you have a small budget and limited knowledge on how these engines are set up, I would suggest you keep everything stock for now and just get it up and running.
Whoever told you you can run the stock computer carb without any of the wires hooked up to it doesn't know what they're talking about. Yes, technically you could run it, but it's wrong on so many levels it's just easier to say 'no you can't'. There is plenty of info here and elsewhere on how the computer works and what it does.
Deleting the AIR pump and all it's nonsense is a good idea IMO. Makes it alot easier to work on your car and your computer will still run just as good without it.
Old Aug 16, 2010 | 10:20 AM
Car: 87 firebird
Engine: carbed 305
the guy that told me has been working restoring and racing sbcs since they came out. he said he was pretty sure i could run without the computer
Old Aug 16, 2010 | 10:40 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
We're more than pretty sure you can't.
Old Aug 16, 2010 | 10:49 AM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
will it run with out it yes will it run right without it no way in hell if you run a non-comp distributor the carb will not adjust the way it's designed too. they are made to work as a team so to speak you gotta go one way or the other either go computer or no computer there's no in between.
Old Aug 16, 2010 | 12:42 PM
DoubleV's Avatar
I got news for ya, most racers don't know squat about how the CCC system works because they never use it. Be carefull about who you get your advice from and always double/triple check your info using other sources. I know if I'd listened to some of the know-all 'racers' and 'oldschoolers' without verifying anything, my car would be a butchered up POS right now that probabaly wouldn't even be running.
Old Aug 16, 2010 | 01:54 PM
Car: 87 firebird
Engine: carbed 305
haha, he doesnt know much about the ccc stuff, he wasnt quite sure. we were planning on using a holley but i couldnt find one cheap enough. he told me to check the forums to make sure. i just dont know what has to be hooked up and what doesnt
Old Aug 16, 2010 | 01:55 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Why not use the stock carb with the stock distributor, and keep the wiring?
Old Aug 16, 2010 | 02:27 PM
Car: 87 firebird
Engine: carbed 305
the wiring is still there. and im planning on it, which is good because i just had a new cap and rotor on my distributor. what about the vacume lines
Old Aug 16, 2010 | 04:13 PM
five7kid's Avatar
The most important vacuum line for the computer is the one that goes to the MAP sensor, located on the firewall in the driver side corner. The rest depend upon which emissions equipment you keep.
The wires that need to be hooked to the carb are the mixture control solenoid (2-wire plug, top front passenger corner of the carb), throttle position sensor (3-wire plug, front driver corner of the carb), and choke thermostat power. Most of our cars also have a fast idle solenoid, but it isn't absolutely necessary for the car to run.
The computer-type distributor has a 3-wire harness that goes from the distributor base to the cap, and a flat 4-wire harness that goes to the firewall harness.
theshackle
Sep 17, 2020 08:26 AM
Genopsyde
Oct 7, 2015 08:35 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
tero
Aug 15, 2015 02:47 PM
matthew911
Aug 12, 2015 09:38 AM
