I NEED HELP ASAP-bracket selection and carb hook up
Old Nov 17, 2010 | 12:37 PM
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Hey everyone I need your help!
I'm doing the TPI to Carb swap and Im at the point of just hookin up the throttle cable, tranny kickdown cable, and crusie control (not manditory)
I have a vortec intake, much like the elderbrock performer intake and a holley 750 carb. I need some help choosing the right bracket to hook it all up and I need help or some pics of the proper way the cables are hooked up to the carb.
Thats what I have sorry for the poor quality of the photo
Old Nov 17, 2010 | 12:57 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: I NEED HELP ASAP-bracket selection and carb hook up
When I swapped my TBI for a carb'd vortec motor, I used the TBI throttle cable, and a stock throttle cable bracket from an 84 T/A and bent it to fit. I had an edelbrock carb, but I can't imagine its much different. Please tell me your going to do something about that wiring harness! :P
Old Nov 17, 2010 | 01:24 PM
Axle/Gears: stock
No i think it adds character!
lol I will I just havnt had the oppurtunity to dig into it, I want to make sure everything is hooked up before I start removing anything or tucking it, just incase I'm missing something.
Old Nov 17, 2010 | 02:51 PM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
I used the TCI geometry corrector for the TV cable and the CSR bracket to get the TPI cables to work (stock throttle and TV cables). The CSR is a little pricey, but after spending WAY too much time on the cheap Mr. Gasket piece, it was well worth the money. I have a Demon carb, so I had to modify the TCI bracket very slightly. you shouldn't have to for a Holley.
Old Nov 20, 2010 | 06:04 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
bowtie overdrives TV MadeEZ, lokar throttle cable, and BO's throttle cable bracket.
Old Nov 30, 2010 | 01:23 PM
Dangerous83's Avatar
Car: 83 z28
Engine: lb9
Transmission: 700r4 b&m shift kit corvette servo
Axle/Gears: 3.73 posi
when i bolted on a holley carb i used pn#s 20-121 carbthrottle& kickdown bracket, 20-37 stud kit and 20-95 kickdown lever for the 700r4. complete setup for around 50 shimolians
Old Nov 30, 2010 | 01:56 PM
Car: 83 z28
Engine: lb9
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
customblackbird
Oct 1, 2015 04:30 PM
Mdenz3
Sep 17, 2015 08:36 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
