change carb wen to go to automatic trans ???
1 Post
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
hello all
i drive with a T5 transmision.
i will make a swap to a automatic transmision (th700r4)
i have a holley double pumper mechanic secondary on the car.
can i drive this carb with a automatic transmision?
or must i change the carb to another carb?
here is the carb i use now!
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
You just need a proper bracket on the throttle arm to correct the geometry for the TV cable, such as this: http://www.summitracing.com/parts/TCI-376715/
1 Post
Car: camaro iroc-z
Re: change carb wen to go to automatic trans ???
i just have that bracket holder!
it came with the lokar gas cable kit before!!!
it is good to hear it will works fine with an automatic transmision!
dennis
dennis
maroe624
04-16-2017 08:29 AM
