Transmission problems after swap? Need you input
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Alright here's my problem. I took out my comp, went to go do the tcc lockup fix and found out my tranny wasn't even plugged in so I didn't worry about it. The other day i took it out for the first time without the tv cable hooked up and drove around a bit then when I hooked the cable up today and took I out it seems like it's not grabbing. I can put it down on first and it feels fine but when I put it in Drive it does it again. It feels like it's not engaging. Anyone know what could be goin on
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
Re: Transmission problems after swap? Need you input
so you drove it with the tv cable unhooked? you lucky you still have 1st gear
Axle/Gears: stock
Does this sound like a tcc prblm? Or maybe a vacumn prblm? Input would be great
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
DO NOT DRIVE THE CAR WITH THE CABLE UNHOOKED.
YOU WILL DESTROY THE TRANS IF YOU DID NOT ALREADY.
you need the correct tv cable kit for your carb.
search around "700r4 tv or kickdown cable"
THAT CABLE CONTROLS LINE PRESSURE,THAT FEELING WAS YOUR CLUTCHES SLIPPING .
Car: 1988 iroc-z
THAT CABLE NEEDS TO BE CONNECTED WITH THE CORRECT BRACKETS AND PROPERLY ADJUSTED OR YOU WILL DESTROY THAT TRANSMISSION.
IT TAKES LESS THAN 20 MILES TO DESTROY THAT TRANS WITH A MISADJUSTED TV CABLE.
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
There's a site that tells how the TV cable works on a 700R4,
TVmadeez or TVmadeeasy, something like that.
Our cable is right & there's no ECM or electric TCC. Gets all gears just fine.
If you can find the site, follow the directions completely.
Our computer crapped out, so I lost alot of saved sites.
Car: 1988 iroc-z
the tcc was only an issue on the early 700r4's,they needed it to stay cool,but mid 80's gm fixed that problem.
i have a switch in my truck (gmc 1500 /5.7 700r4 4x4) to shut off the tcc when i tow or haul or have my plow on.
the owner before me had it unplugged for 8 years.
Axle/Gears: stock
I was thinking that the TV cable was only for controlling downshifting. Found out it controls line pressure and shift points as well. What my car was actually doing was "stacking shifts" because the cable was too loose. I found a website that gives 700R4/200R4 TV Cable Adjustmant Instructions. Ill get it adjusted tomorrow when theirs light outside and let yall know how it did. Thanks for all the input, it def led me in the right direction!
The website I found was:
http://www.tciauto.com/Products/Inst...ble_adjust.htm
Axle/Gears: stock
The website does have a lot of information on how the TV cable works with 700R4 and 200R4 though. Really informative, thanks for the help
Car: 1988 iroc-z
BlackphantomZ28
Apr 24, 2016 08:14 AM
