edl 1406 or 1407?
Car: 1992 Camaro Z28
Axle/Gears: factory 373
edl 1406 or 1407?
i have a 350 engine with no ecu or harness...i build the bottem end, should be.40 over and 10 to 1 compression. i have a small to mild edl cam in it, holly fuel pump and regulator. it was factory heads and springs for now..edl rpm intake.
i have a 1407 and a 1406 edlebrock carb at my house. 1407 is brand new and 1406 i just rebuilt.
i was told that the 1407 is way to big for a 350....thats maybe why i have slow acceleration
so what carb should i use???????
i would buy a holley. but i have all this at my house i dont feel like wasting money, there is other things in the car that has to be done..
Transmission: 4L80E/4L80E
The 1407 isn't "way too big", but it is probably bigger than you need. The 1406 may be a bit too small.
It probably is not why you have "slow acceleration".
Start with some details. Exactly what cam? What distributor? Where is the timing set? Are you setting the timing with the vacuum advance disconnected and the engine at an idle? Are you sure you have the correct damper and timing tab? Stock "what" heads?
A "mild" cam and an RPM intake may be the biggest mismatch, although factory valve springs and aftermarket cams rarely play well together. But, even the intake shouldn't hurt that much, especially once you get over 1500-2000 RPMs.
Re: edl 1406 or 1407?
oooooookkkkkkkkkkkkk ready for this.....
bought the car as a project......i decided to make it old school carbed with a 350
so i brought to a macanic to do the swap...5 months later all he did was take out the engine and didnt lable nothing then went out of busness...so i was self with a buetiful z28 with no engine and no knowlege of cars....so i took the car back, with help from no one ....exept this forum...i decided to do it my self....
my second problem is i did the worst thing i bough a engine online ...and the guy who sold it to me screwed me hard...i didnt get what i paid for and it was used parts when it was sappost to be new, and it was siezed...nice right...
i brough it to mechine shop down here in Rhode island and got the bottom all set, that cost me another 950.....but they couldnt find out what cam it was but i do have the measurments. so i basiclly bought everything from summit and this is what it look like i have
Head casting number 333882 year 70-80 1.94/1.50 76ccEngine casting number V0927TKK C8J110322flexplate - 153 toothsummit racing box SUM-850600summit racing SUM-850001R HEI distributor (trigger style-magnetic)(advance type- vacuum and mechanical)sum-829000 starterwater pump EDL-8811 Edelbrock victory series mechanical water pumpMr gasket-4363 thermostat 160 degreeEDL-1411 carb 750 CFM ELEC CHOKEHOLLY 12-327-12 holly pro-series mechanical fuel pump 130 gph -7.5 to 9 psiHOLLY HLY-12-704 holly fuel pressure regulator 4.5 -9 psiSummit Racing SUM-G1667A - 100amp BBM-70418 TORK master 2400BMM-70235 TRANSPAK 700R4tci trans lock upcams measurements is 460/484 lftThe bottom is built but heads are not...i FINIALLY GOT THE CAR TO RUN LAST YEAR~!!! fouth time driving it i got hit by a drunk driver....bummer huhso its getting a new front end and paint job im getting it back next week!! so im getting this baby ready!im 24 now..i was 20 when i purchased the car drove it about 4 times and put around 12 grand into it..i want this thing running goodi have all the tpi cables in(Throttle and tv) there way to long so the first thing im doing is getting the TBI ones with the right brackets and stuff..but i was told this carb was way to big...aany help would be AWSOME! i can show pics it looks great!
Performer Intake Manifold Edelbrock 5,500 RPM* i dont have the car at my house too look at the model number but i "THINK" this is the one..could be wrong though.
Okay, that helps a lot.
Heads - I was afraid of that. About the worst things ever to come out of the factory. No matter what else you do, they will keep it from realizing its potential.
Cam - Sounds like serious lift, but without knowing the duration, still hard to say. Most likely it's better than the typical "RV" cam.
Intake - From the sounds of the cam, it may be fine, may actually be better to have the RPM...
Distributor - Good. Set the initial timing at at least 12 degrees BTDC at idle with the vacuum advance disconnected. If your damper is marked for advance beyond the timing tab, sit the timing for 36 degrees total mechanical advance (RPMs up to where timing isn't advancing any more, vacuum advance disconnected) and let the initial timing be whatever it wants to be.
So, what are you willing to improve? As much as I dislike Edelbrock carbs, I dislike 882 heads even more. The cam is the heart of the engine, it's always good to know what you've got.
[quote=five7kid;4859093]Okay, that helps a lot.
how much u think it would be for a ok set of heads to help me HP? Somthing i wouldnt have tot ake the engine out for.....but i should just put a cam i have the card to so i could know?
thanks alot...atleast i dont have junk?
how much HP u think i have with this?
Car: 1985 Firebird
Engine: 355 Sbc Edelbrock Rpm Performer
Axle/Gears: 3.42 One wheel Peel
Hello Defaria27
I was just looking on the forums and posting some parts for sale and noticed you need a little help being stuck with those 882 heads. I just listed some parts for sale you maybe interested in taking a look at. A brand new set of Edelbrock RPM performer heads would work well with your setup. I am currently located in Boston, Ma for the time being which is where you are correct? And if you are looking for some experienced help I am willing to lend a hand. I have built a few of these performance cars and don't mind getting my hands dirty to help a fellow car guy.
I also have a nice performance camshaft, lifters, and a full exhaust. Plus a ton of other parts as I am moving to Pennsylvania in July. I am looking to get rid of some parts and help you get this car running the way it should.
Shoot me over an email and we can talk; dborrelli24@yahoo.com
Check out my post from earlier today tell me if your interested
https://www.thirdgen.org/forums/engi...ers-1-3-a.html
Thanks Daniel
Thanks Daniel
theshackle
Sep 17, 2020 08:26 AM
86IROC112
Aug 17, 2015 02:00 PM
