Run-on
Old Apr 2, 2011 | 11:18 AM
steven72192's Avatar
Run-on
i have an 83 camaro z28 and wen i turn the key off it sounds like my engines about to blow up. i took all of the emissions components out as well and the computer so my stock electric carb is not controlled by the computer any longer. but after i timed the car and got everything running pretty good for the past copule months alomost every time i shut the car off theres run on. any sugesstions what my problem might b?
Old Apr 2, 2011 | 08:39 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Re: Run-on
Just a guess, but a cc controlled carb needs the computer to run maybe?
Old Apr 2, 2011 | 09:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Either put the computer back in and whatever it needs to operate properly, or replace the carb & distributor with non-computer stuff.
There are no other choices. You will NEVER get it to run properly with what you've done to it without doing one of those two things (and you can't do it half-way - either one, or the other - no other choices).
Old Apr 3, 2011 | 09:32 AM
Re: Run-on
that was my next step, butalso when i did put the computer back it it retarded timeing so bad the car wouldnt even stay on it would shut of alomost automatically so thats another reasont the computer came out. but any sugestions on what kind of dis. or carb to buy. i heard msd and holley are really good. any personal sugestions?
Old Apr 4, 2011 | 01:25 AM
DoubleV's Avatar
Re: Run-on
How do you know the computer was retarding your timing?
IMO, you should put everything back to factory stock and get it running correctly. If it's not running correctly on the computer, then that means there's a problem somewhere. Fix that problems(s) and you'll be happy. A good service manual has all the step by step procedures to diagnose and repair eveything.
I just don't think it wise to switch out one thing for another just because you can't fix something. You'll just end up with a different set of problems when changing over to something different, only now when you run into problems you can't refer to your trusty service manual.
Old Apr 4, 2011 | 11:48 AM
Re: Run-on
before i removed all of the emissions and ac components i bought a chiltons manual and read that but when i bought the car half of the emission were disconnected anyways there was no belt for the air pump or ac compressor so i just removed them, also most of the hoses for egr, pcv, canister etc. were spliced and not connected to anything most were not even plugged in so i removed all of them. and i believe it was the computer that retarded timing because wen i was setting timing i had the computer in, i could not set it the car set back and stalled out the sec i remived the computer everything was ok. so i am still puzzled i was wondering if there was any adjustments to be made on the carb itself?
Old Apr 4, 2011 | 12:06 PM
74Novaguy's Avatar
Car: 88 Camaro IROC-Z
Engine: 5.7L 350 TPI
Axle/Gears: Stock
Re: Run-on
Did you disconnect the ETC connector before trying to set your timing if not then that may be your problem when you had the computer in the car... if your going to complete the switch any non cc distro will work. it sounds like your motor is stock so no need to spend 400 dollars on a disto. holly or edelbrock carb will work. vacuum secondary if you have an automatic. holleys are better at the top end but require alot of adjusting. edelbrocks seem to be good all around and require less adjustment. I perfer holleys but thats just my opinion.
Old Apr 4, 2011 | 12:20 PM
Re: Run-on
yes the motor is a stock 305 with a 4bbl carb now and i am looking in to a new dis, and carb, holley was one of my first choice to i heard alot of good things about them and like u said alot of adjusting also and as far as a dis. msd? or any other personal opinoins?
Old Apr 4, 2011 | 12:39 PM
74Novaguy's Avatar
Axle/Gears: Stock
Re: Run-on
MSD is good but you'll be spending alot of money for a stock motor. Proform (cheap) but work well. I just picked up a CC one for my TPI setup for 140 dollars from summit. summit sells there own brand distro for like 90 dollars which should work in your case.
http://www.summitracing.com/parts/SUM-850001R/
Old Apr 4, 2011 | 12:50 PM
Re: Run-on
thanks
87SSTPI
Aug 14, 2010 04:10 PM
dennisbernal91z
Carburetors
Aug 17, 2007 07:02 AM
drembedded
Oct 23, 2005 04:20 PM
86TA305Ga
Carburetors
Mar 19, 2005 07:08 PM
Matty377
Aug 14, 2002 10:43 AM
