cold start requires pumping gas pedal?
Old Apr 23, 2011 | 12:47 PM
Handmedown86's Avatar
Hey guys,
I just joined this board today to hopefully get some answers. Father-n-law sold me an 86 Z28 w/305 carb for $500. for a cold start, i have to pat the gas pedal about 30+ times to get it running. After that it starts right up fine. Seems its loosing vacuum? Thanks ahead of time for the help.
Old Apr 23, 2011 | 03:10 PM
EvilCartman's Avatar
Car: '82 Z28
Re: cold start requires pumping gas pedal?
Should only take one or two pumps at most. If you haven't tried starting it today, go out there, take the air filter housing off, pull back the choke blade so you can have a look down the small primary boosters of the carb. Work the throttle and see if any gas is shooting out, if there was, go ahead and try to start it without pumping the gas any more. If nothing is coming out then the gas is draining back out of the carb or the gas is just evaporating out of the fuel bowl.
Old Apr 23, 2011 | 11:27 PM
DoubleV's Avatar
Is the choke setting? In other words, does the flapper above the primaries snap shut when you fist pump the gas? If it doesn't, that's most likely your problem along with the possibility of what EvilCartman says about the gas leaking out of the carb overnight ( leaky well plugs ).
Old Apr 23, 2011 | 11:54 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
With the warmer weather here now, I doubt its anything to do with a choke. I have a Mighty Demon carb, theres not even a place to mount a choke, and even with my motor built like it is, 1 pump of the gas pedal and it fires right up. Does the same even if it gets into the 30's. The choke will let it run when cold without having to hold the gas down, but shouldnt stop it from firing up.
Old Apr 24, 2011 | 05:13 PM
Car: '82 Z28
I've found that q-jets need a choke even when warmer weather is around, or at least the one on my other car does. Like yours, my race Demon will start up in cold weather without much trouble.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
johanlindgren
Aug 16, 2015 12:16 AM
355tpipickup
Aug 13, 2015 07:35 AM
drathaar907
Aug 6, 2015 04:20 PM
