305 tbi keep tbi or go carbed
Old Apr 23, 2011 | 04:45 PM
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
hey guys im gathering parts as i go and got a lil collection
and i was wondering
would it be worth going to carb
or just keep tbi and mess with the ecm (PITA)
best for power and funds
thanks!
(IDK IF THIS S IN RIGHT BI}OARD)
Old Apr 23, 2011 | 05:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Re: 305 tbi keep tbi or go carbed
You can do more, and more easily by swapping to carb (in my opinion). I say this because for me, learning the software, programming, buying all the programming stuff, etc. was just not my cup of tea.
And in NC, you can get away with it (as long as you go to a Joe Blow shop not in an emissions county for an inspection).
But know it's not cheap. Carb $250 - $400, intake $200 - $300, fpr $100, dist $125, TC lockup $100, another $150 misc parts - that's almost $1000 (in new parts prices).
But, you can then do anything you desire motor-wise without trying to reprogram some chip to understand it.
But also recognize ... gas is hitting $4 a gallon, and you'll cut your mileage in half instantly going to carb ... you should be getting close to 30 hiway now, you'll be extremely lucky to ever see 20 after a carb swap. My current setup I get 17mpg hiway.
Old Apr 23, 2011 | 09:30 PM
one92rs's Avatar
Car: SOLD!!!!!
first go to the tbi section and read. i went to carb and enjoyed it for a little while. a holley carb is a never ending adjustment project as well. and unless you are good with carbs it is a pita. and if they say it doesnt need adjustment they are lieing to you.t is is a mechanical advance which will also have to be played with.
i went back to tbi and maybe lost a lil hp up top. but the driveability all around is better. do the ultimate tbi mods. then read thru the tbi part of the forum. get a chip from harris performance after you are thru and go from there. unless you like messing with it most of the time i would stay with tbi. you will only be giving up a few ponies for a lot less headache.
and like stated above you will have to find a way to control the tranny lock up.
Old Apr 24, 2011 | 08:11 PM
dabird07's Avatar
Car: 92 firebird
is it possible to stick with the ecm and hook it up to the carb??
and ure getting 17 m to the gallon?
with a 350?
my setup is gettin 165 miles a tank with a 305 .. . (but with speedin)
and imma check that website !!
Old Apr 24, 2011 | 08:36 PM
Car: 1992 RS
Engine: Carbed 350
NO, can't use the ECM and a carb.
Old Apr 24, 2011 | 08:47 PM
one92rs's Avatar
Car: SOLD!!!!!
wow those are some high prices. an edelbrock performer eps intake can be had for around 130.00. fpr for around 70.00/ toggle for tc lock up and wire for less than 20.00. good working hei dizzy can be had for under 100.00 on ebay.
Old Apr 24, 2011 | 10:35 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Iv messed around trying to tune TBI / Speed density systems for years. you'll have more time invested then you ever would want to know and about $500 to $1000 in programmers, burners, chips, software, tools, wide bands, home fabricated MAF setups to measure incoming air, laptops and that's a ball park on the cheap end of things. I swap to carb simplicity over completely. nothing but metering rods and jets switches from here on out. The only nice car to tune was one of my 4thgens that had a flash-able PCM, that only took a ALDL cable and some software.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
Dwayne614
Sep 28, 2015 08:33 AM
