Air gap fit?
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
Air gap fit?
Will a edelbrock air gap intake w a edelbrock performer carb fit under the stock hood of my 86 Iroc z
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Air gap fit?
Yes, it will. The Air Gap RPM is the same height as a Performer RPM, and many of us have a Performer RPM under s astock hood.
The drop-base ... I didn't like it - have to use a 1/2 inch spacer for it to clear the linkage, then use a 2 1/2 inch element for it to fit - then it still rubs the ign wires at the distributor. After all that - when you look in the side, you'll see there's very little space for air to actually flow (because it drops so much).
I went with a Spectre 9inch non-drop. It does not drop, so no linkage/choke worries, fits great with the 2 inch element it comes with giving you a full 2 inches of airflow all around, and at only 9 inches, you see more engine and no ign wire rubbing issues. They are on the shelf at AutoZone for $29 with a rechargeable (like K&N) filter.
Dialed_In
Aug 20, 2015 01:45 PM
