bit of a n00b question
Old Jun 6, 2011 | 02:47 PM
89rs358's Avatar
Car: 89 rs 358 / 99 wrangler 4.0
Engine: 358
Transmission: t5
Axle/Gears: 393 12 bolt
ive owned my camaro for about a year now but honestly have only driven it maybe 20 times, due to the PO not doing a good job on the wiring and such, it was pretty embarrassing when people would ask me to pop the hood when i would stop and it was a mess, well ive got it to where i want it now and would like to drive it and show it off a bit, but while i was cleaning up the wiring i removed the old electric choke (holley 750 on a 358) as it was not working anyway and there was already a manual choke in place, so i just hooked up the linkage and called it a day, but the problem is when i turn it on i have to give it gas for a minute or 2 in order to keep it idling, i printed out the manual for the carb i have and it says i should have a "high speed idle" that would fix this while the choke is closed it should run off the high speed idle, but the picture in the manual shows it as part of the electric choke, i went out and looked at mine and the adjustment screw is still there but it doesnt seem to do anything, so is this an adjustment only for elec. chokes? thanks in advance for any help!
heres a pic from a few weeks ago, ive cleaned it up a little bit more, but no pics
Old Jun 7, 2011 | 06:24 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
Re: bit of a n00b question
I would think so
Old Jun 8, 2011 | 03:44 AM
89rs358's Avatar
Engine: 358
Transmission: t5
thanks for the response, guess ill just keep on given her some gas lol, its not to bad , just being picky
Old Jun 8, 2011 | 04:12 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
my whole iroc restores been 'picky' i like it better that way. and i would assume so as well, my tpi still does that occasionally to.
Old Jun 8, 2011 | 04:28 AM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
Keep gasing or pull that manual choke just a tad
Old Jun 8, 2011 | 01:52 PM
89rs358's Avatar
Engine: 358
Transmission: t5
ya im going to see if i can find a better choke cable i guess, the one i am using now sticks pretty bad and its a pain in the a$$ to adjust it, either full open or closed basically
Old Jun 9, 2011 | 09:59 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
you can always put a working electric choke on it, its just 1 wire that needs to be hooked up, run it out of site and it wont affect the looks of the engine bay.
beastin91rs
Oct 9, 2015 07:38 AM
NiG
Sep 2, 2015 06:54 AM
CORV3TT3
Aug 23, 2015 11:26 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
