I need some help
Old Dec 14, 2011 | 01:36 AM
86I-ROCZ's Avatar
Car: 86 I-Roc
Engine: 305 Carb'd
I need some help
So i just picked up a 86 I-roc z about 2 months ago, I traded a guy off craigslist for my 95 Bronco on 35's.
Yeah theres a few things wrong with the car but ****, parts are so cheap!
So right now im having a problem, my carb is way to big for my 350 small block. I get a huge amount of lagg when i get up in the rpm's, i can really only have the car at half the pedal through. It will sit there and backfire while my rpm's SLOWLYYYYYYYY climb. I through some hotter plugs in it and a new fuel pump since mine sputtered gas all over itself, but i still need less carb.
I have a Weber 650 in my garage that i got from a friend, would that be a good match for my engine?
Old Dec 14, 2011 | 06:43 AM
NCGuy68's Avatar
Car: A lousy LS1 car
Engine: 347 Cu. In.
Transmission: Which One?
Re: I need some help
We'll need more info to answer your question.
Is the original factory 350 in the car?
What carb is on the motor?
What makes you think the carb is too big?
Old Dec 14, 2011 | 06:47 AM
NCGuy68's Avatar
Engine: 347 Cu. In.
Ops, you said the motor is a 350. What year? Is it stock?
Old Dec 14, 2011 | 09:07 AM
86I-ROCZ's Avatar
Car: 86 I-Roc
Engine: 305 Carb'd
I have no idea what year the engine is, but the guy i got it from swapped it in.
And the reason its the carb is because
1. My car reaks of gas
2. It bogs out when i put my foot to the floor
Old Dec 14, 2011 | 01:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What carb do you have? What distributor does it have?
We can't provide help until you provide information.
Most likely your carb isn't "too big", but just needs some help. A "Weber 650" probably isn't the answer.
Old Dec 14, 2011 | 02:08 PM
Andrew James's Avatar
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
Should have kept the FSB.
Old Dec 14, 2011 | 05:57 PM
86I-ROCZ's Avatar
Car: 86 I-Roc
Engine: 305 Carb'd
Stock distributor, And i have no idea whats on it right now
Old Dec 15, 2011 | 12:11 AM
five7kid's Avatar
Then take a picture and post it.
Aftermarket carb and stock distributor don't play well together. It will run poorly, no power, run rich...
Old Dec 15, 2011 | 12:40 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
just a thought,but in my younger learning years i found out that you get this same effect when you go from a 2 barrel to a 4 because the heads and valves are too small. So was your car a TBI car,or a carb car originally,................
Old Dec 15, 2011 | 12:39 PM
five7kid's Avatar
That can be a power potential problem, but not produce the symptoms described.
Old Dec 15, 2011 | 04:39 PM
86I-ROCZ's Avatar
Car: 86 I-Roc
Engine: 305 Carb'd
Old Dec 15, 2011 | 05:05 PM
five7kid's Avatar
That's a non-computer quadrajet and a non-computer distributor.
Start with ignition timing. You should have around 12 degrees BTDC at idle with vacuum advance disconnected. If you set it at zero like the sticker says, the engine will be a dog.
After you have that set right (assuming the plugs, wires, cap, rotor are all in good condition), then read through this: https://www.thirdgen.org/quadrajet Although the title says "computer-controlled", everything applies until the last part about "other tuning for Camaros and Firebirds". One thing I see in your pictures is the accelerator pump rod is in the outer hole - you'll get a better accelerator pump shot with it in the inner hole.
That carb is not too big for a 350. It just needs to be properly set so it can operate correctly. The Weber would be a serous downgrade (and probably won't bolt to the intake manifold).
Old Dec 15, 2011 | 05:14 PM
five7kid's Avatar
Oh, it appears the choke is tied open with a nylon tie. Get rid of that tie. If the choke isn't working properly, then fix what's wrong. Tying it open is just wrong-headed.
I can't see from your pics if the link between the choke pull-off ("vacuum break") is there. If not, then replace it. The pull-off is part of the "quadrabog mitigation" hardware (what you are describing is classic quadrabog).
Old Dec 15, 2011 | 05:39 PM
86I-ROCZ's Avatar
Car: 86 I-Roc
Engine: 305 Carb'd
Choke is set like that because its a manual choke, the guy didnt hook it up. So thats the only way i can start it in the morning.
We adjusted the throw so it would guzzle less gas
Old Dec 15, 2011 | 06:09 PM
five7kid's Avatar
Unless it's been gutted, all of the electric choke parts appear to be there.
In the attached pic, where do the lines go that are circled? Not properly routed could be part of your problems.
File Type: pdf
Old Dec 15, 2011 | 06:23 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by 86I-ROCZ
It will sit there and backfire while my rpm's SLOWLYYYYYYYY climb....
Check for a defective accelerator pump...
Old Dec 17, 2011 | 12:18 PM
86I-ROCZ's Avatar
Car: 86 I-Roc
Engine: 305 Carb'd
ill check here in a bout an hour as to where those lines go
Old Dec 18, 2011 | 09:40 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
The accelerator doesn't guzzle gas. It will fix part of your problem. I would trade a .25 mpg loss foe a car that runs right. And +2 on getting the choke working.
Old Dec 18, 2011 | 05:46 PM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
I'd get a new intake and Holley 600 vacuum secondary carb.
