Holley throttle cable bracket
Old Dec 28, 2011 | 10:14 PM
85_ZED28's Avatar
Car: '85 Z28
Hi guys,
Has anyone tried one of these type throttle cable brackets with a big drop base air cleaner? (have a Performer RPM intake and Holley 670 street avenger carb):
http://www.ebay.com/itm/Throttle-Cab...item2c61ba5f0f
It looks like it may interfere with a drop base.
Also, can the stock bracket be made to work with this setup? What are you holley guys running? It's a T5.
Thanks!
Colin
Old Dec 30, 2011 | 02:54 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Holley throttle cable bracket
was it originally a tbi, tpi, or carbed car? i run a spectre universal throttle cable and bracket and it has to be bent down a little to fit under my 1.5" drop base air cleaner. i dont like the way the bracket looks though and will be swapping it out to something else one of these days.
Old Dec 30, 2011 | 03:28 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
It works fine, regular old Double Pumper:
Im also running a manual, so I dont have to worry about the TV cable either. There is adjustability for the TV cable too, but that part of the kit is isnt necessary for us. I wholeheartedly endorse investing in a good billet bracket. It wont bend and twist when youre trying to go WOT. Plus they look nice.
However, be aware the return springs on these things can be pretty stout. Mine have worn in nicely over the years, but it's still a lot heavier than stock. I dont mind it at all, though.
Old Dec 30, 2011 | 04:42 PM
travis401's Avatar
Car: 91 Camaro RS
how much of a drop is your aircleaner base infernal?
Old Dec 30, 2011 | 10:43 PM
Car: 1992 Camaro RS
I think it's an inch drop. It's pretty deep. May be 3/4 inch depending on how you measure it. The filter is a 1.5 inch unit. I need to move up to a 2 inch, but that one is 1.5, so yuo can see. Im pretty sure it's about your standard drop base. Previous owner of my car was able to fit a 3.5 inch filter on the stock TBI with the stock hood and a half inch spacer.
Old Dec 31, 2011 | 09:35 AM
travis401's Avatar
Car: 91 Camaro RS
yea, ive got the 1.5" drop and the spectre universal bracket gets in the way barely. i had to bend it down just a tad. i may have to chance it and get one of the billet brackets and see if it clears.
Old Dec 31, 2011 | 10:12 AM
one92rs's Avatar
Car: SOLD!!!!!
i ran one when i was carbed.
Old Dec 31, 2011 | 02:50 PM
85_ZED28's Avatar
Car: '85 Z28
Thanks for the input guys. I have a drop base I'm hoping to use from the ramairbox.com setup, but it's a big drop. I'll have to measure it.
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
hydrolic144
Oct 4, 2015 08:23 PM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
