High Idle...Help identifying a SENSOR...
Old Apr 12, 2012 | 07:38 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Hey I got a 84 z28 carbed engine(manual transmission) and for some reason someone told me that by replacing this sensor that could fi my problem,but I just dont know what this sensors name is, please help. I wanna go to autozone and purchase the sensor but IDK what its called so I just need the name of it, or any other suggestions as to why my car is idling high, thanks!
">Name:  IMAG0822.jpg
Size:  55.1 KBhttp://">http://
">Name:  IMAG0817.jpg
">Name:  IMAG0815.jpg
Old Apr 12, 2012 | 07:55 PM
rrf321's Avatar
Car: 91 formula
Engine: 5.7 not o.e.
Axle/Gears: 273 2 wheel drive
Re: High Idle...Help identifying a SENSOR...
where its at it appears to be a coolant temp sensor
Old Apr 12, 2012 | 08:03 PM
calgutie's Avatar
Car: 1984 Z28
ohhh okay i see...and is that jusyt what i tell the people @ autozone then>?
Old Apr 12, 2012 | 08:15 PM
rrf321's Avatar
Car: 91 formula
yep that and take the pics you just showed us
Old Apr 12, 2012 | 08:22 PM
calgutie's Avatar
Car: 1984 Z28
thanks for the help and another qikc questions....so i changed my air filter and now I got smoke comming ou of this "hole" is there anything I can do to stop that?thanks!
">Name:  IMAG0823.jpg
Old Apr 12, 2012 | 08:34 PM
rrf321's Avatar
Car: 91 formula
i think that used to go to the stock air cleaner.the purpose was to warm the carb faster on cold start.but i thought it was like a shroud around the exhaust maifold that the heat came from. is your valve cover gaskets leaking onto the ex. manifold?
Old Apr 12, 2012 | 09:52 PM
calgutie's Avatar
Car: 1984 Z28
I dotn beleive so, its just that every time when I park my car smoke comes out of the ood and when I look under that from where the smoke is coming out from, and I was just wondering if there was something I could do, to rpevent that from happenning.
Old Apr 12, 2012 | 10:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You may need to replace the CTS connector along with the CTS (in fact, the connector may be the problem).
Can we assume your car still has the factory type carb on it?
Old Apr 12, 2012 | 10:33 PM
calgutie's Avatar
Car: 1984 Z28
Yes it is stock, and what is the CTS connector?
Old Apr 13, 2012 | 04:34 AM
rrf321's Avatar
Car: 91 formula
Coolant Temp Sensor
Old Apr 13, 2012 | 08:28 AM
When you buy a new CTS, it usually comes with a pigtail with a new connector that's a MUCH better design, because that old stewpid one like in the pic, always fails, just like the one in the pic has failed; just open the box and make sure there's one there when you get it.
You're going to need to lose the bad-idea open-element air cleaner and put the stock one back on, along with the crinkly sort of flexy tube that goes to the air cleaner from that heat stove on the exhaust manifold, if you want to pass California inspection. I notice that it had a nub of that in the first pic but was gone in the 2nd one... needs to be restored intact.
The reason smoke comes out of that hole, is because the valve cover gasket RIGHT IMMEDIATELY ABOVE IT is leaking; and the oil drips down onto the manifold and burns.
I hate to rain on your parade, but looking at what I see in that pic, you've got A LONG WAY to go to "fix" that thing, besides just the one sensor... but it's a good start.
Old Apr 13, 2012 | 11:02 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Replace your CTS, but it's probably not the reason for the high idle. Check all of those vacuum lines that are, or are not, hooked up properly. Bet you find a leak somewhere.
With the CTS not connected the vehicle will always be in warm-up mode, the ECM things the engine is always too cold for open loop. This will cause an excessive rich mixture and all together crappy mileage and performance.
Old Apr 13, 2012 | 03:45 PM
rrf321's Avatar
Car: 91 formula
Also in pic 4 it looks like a broken hose. Cant see for sure where it goes might be your vacuum leak. another one to check in pic 4, by the heater hose, of the water pump looks like a vacuum hose t connector that is open. How long have you had this car?
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
