Holley 670 Street Avenger VS Stock CC QJet?
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I have a new 670 Street Avenger sitting in my Shop, How does it compare to the stock Q Jet? What do I need to change to put it on? HEI? Anything else? Thanks
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Carb Type___________E4ME Q-jet________670 Avenger
Emissions legal?------------Yes-------------------No
Requires new dizzy?---------No------------------Yes
Requires new intake?--------No------------------Yes (Performer is okay, though)
Reduced fuel economy?------No------------------Yes
Good with a T5?-------Not the best---------------NO!
Car: 86 Z28
Re: Holley 670 Street Avenger VS Stock CC QJet?
Five7Kid Do you have a Carb you Recommend for me then?
Car: 86 Z28
Trying to try to see if I go away from the computer if it'll solve my problem, been fighting it for years, after fire issue on Decel, I have tried everything and the only thing that has stopped it is if I disc the four wire pin at the Dist, car has no power but will not pop on decel either.
Car: 1984 Trans Am
Axle/Gears: 3:73
Car: 86 Z28
Do you think the Double Pumper would be too much for my application? I am guessing a 650 or would you go with a 750?
Street Lethal
04-30-2019 12:14 PM
9192camaro
16
02-03-2019 12:21 AM
