Choke and fuel pump issues
Ok I have a87 that I just replaced the pump sending unit refurbished the tank with por15 cause it was rusty and did a carb rebuild on and the carb floods out with the electric pump hooked up so I pulled the fuse and it will start and not flood I am also having issues with the carbs electric choke it s not disengaging so it won't let the secondaries open any ideas also how do I post new threads
Transmission: 4L80E/4L80E
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Choke and fuel pump issues
Make sure the single wire connector is connected to the choke and that it provides 12 volts when the engine is running. The choke only gets voltage when the alternator is working correctly. The 'choke' light is kinda an 'alternator' light. With it connected and getting proper voltage, the choke should be completely open within about 3-5 minutes of running.
http://m.youtube.com/my_videos#/watch?v=5TQ26W4PQ70 here is a link to a video of what my car is doing
Heres another link http://m.youtube.com/my_videos#/watch?v=8-TuLAUL1Uk
Check the choke wire with the engine running.
Voltage at the battery with engine off should be mid - 12 volts. If it goes up to about 13.5 with the engine running your alternator is fine.
Chase down the choke relay. Choke light on dash is working? On with key in run/engine off?
No. Fix it right. Chase down the choke relay, it's the next most common failure part.
What Naf said. Fix it right. Choke relay is a common failure point and the next thing on the list to replace to see if it fixes the choke voltage problem.
I believe there is also a diagram of the choke wiring system in the stickies at the top of this page. It is NOT straight-forward or intuative. No sane person would have designed it this way. But GM did.
Ok so its been a little while since I messed with this but still havering issues I figured out the choke light issue it was the fuse that I pulled for the fuel pump for some reason it is also connected with the choke. Now it is just dumping fuel again I put a regulator on it but don't know what the pressure should be. also how many turns do I put the screw on the choke side, the screws on the bottom of the carb in front, the little ones on top on front of idle mixture that you have to remove the caps to adjust,and mixture screw. I know most are not supposed to be used or messed with but the guy (s) before me had.I'm just trying to get it back to factory.
Ps. Im sorry about the"No" in previous post I misunderstood and didn't mean it like it looked. And I was just using jumper wire as temp to try and tune carb in and see if that fixed it at all. lesson learned don't remove fuses
If they've been dickered with you can try setting the idle mixture screws (front bottom two) and the IAB (top of airhorn) to four turns out on each. First check where they're at now and if within 1 turn of 4, reset to original positions. Otherwise 4 turns out will be a good starting point.
Read thru the carb sticky for setting the curb idle speed and fast idle speed. Make sure the timing is set correctly and ignition (plugs, wires, cap, rotor) are all known good or new before doing any other adjustments.
Car: 83 Z28 Crossfire
Fuel pressure should be about 5.5 to 6.5 PSI. Set that before you do anything else.
Oh another thing too is when I press on the break and let off the carb starts clicking and does out and no its not the one way valve from the break booster I checked that.
Thanks again for all the help. I'm just getting so feed up with this thing...lol
92camaroJoe
Aug 13, 2015 06:07 AM
