Quick! What is this?! Qjet small little cone thing E4ME
Old Jul 26, 2012 | 08:57 PM
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
Where does this go?
Silver pin on bottom. I have a replacement bronze one in the rebuild kit.
Attached Thumbnails Quick! What is this?! Qjet small little cone thing E4ME-img_20120726_215259.jpg
Old Jul 27, 2012 | 02:14 AM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Re: Quick! What is this?! Qjet small little cone thing E4ME
It's a vacuum port on the front of the carb. Look straight on and you should see it.
Old Jul 27, 2012 | 06:37 AM
Not a vacuum port...
It's a plug for the MCS lean adjustment hole.
Old Jul 28, 2012 | 01:57 AM
Engine: L69
Transmission: A4
I must not be looking at the same thing then....
Old Jul 29, 2012 | 01:31 PM
Car: 82,83,99 T/As
Engine: 350,350,383
Thanks sofa!
Old Jul 29, 2012 | 06:11 PM
Jack Pomerleau's Avatar
Your picture is of a plug used for the adjusters that pass thru the top of the carb lid. they go in and hold the adjustment and seal the hole at the same time. Depending on the carb it self you could have up to 3 in the lid of the carb. Good Luck
Old Jul 30, 2012 | 11:40 PM
Car: 82,83,99 T/As
Engine: 350,350,383
Thanks man. Is it necessary to have all plugged? Or can I leave them uncapped?
Old Aug 1, 2012 | 05:51 AM
Damon's Avatar
It's open to the float bowl on the inside so..... you probably don't want dirt and debris falling in there.
Old Aug 1, 2012 | 07:54 AM
Problem with having it plugged is, once you put it in there, you then have to disassemble the carb to get it out so you can tune the adjustment.
The factory designed it that way to prevent exactly what we here are usually doing: "tampering".
It'd be better to leave it out, and find something less permanent to put in there, like a rubber one or some such.
Old Aug 1, 2012 | 11:56 AM
Car: 82,83,99 T/As
Engine: 350,350,383
Gotcha.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Bob88GTA
Aug 18, 2015 03:31 PM
86White_T/A305
Aug 17, 2015 12:16 AM
