Is my sending unit ok for new carb
Old Sep 8, 2012 | 10:37 PM
Sidethumper's Avatar
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
I have dropped the feul tank to get all of the old gas out of it that sat for 12 years. I just want to make sure that the sending unit that is in the tank now will be ok with the beefed up 350 and 600 to 700 cfm carb I plan on putting on the new motor (not sure what I want to put on yet ... still learning) The sending unit is 25 years old but it was working fine when the 305 motor was in it and I had to move the car to my garage even with the 12 year old gas in it !!
Old Sep 8, 2012 | 11:22 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Re: Is my sending unit ok for new carb
Check with an ohmmeter "0Ωs Empty / 90Ωs Full".
If you get this readings without any bad spots when move the float lever up and down you should be good to go.
Old Sep 11, 2012 | 05:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Put a new pickup sock on while you have the tank out.
The 3/8" pickup line is sufficient to supply more power than you'll make with a 700 CFM carb.
Old Sep 11, 2012 | 08:29 PM
What about the vapor line? I deleted it so do I plug the hose or put a feul filter on it?
Old Sep 12, 2012 | 10:08 AM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Don't plug the vapor line, if it gets clogged or plugged you will have a ton of built up pressure that you don't want. A fuel filter will work fine.
Old Sep 13, 2012 | 07:10 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
I'm assuming he meant the one that goes to the charcoal canister. Yea, plug that line right at the tank if you can. Just make sure your vent line is in good working order.
Old Sep 13, 2012 | 08:31 PM
Yea the vent line is working fine , it has a piece of plastic broke off where it mounted at . I hear GM discontinued it so don't know where I will find one.
I was wondering about that vapor line because if that is not pluged then the vent is usless lol.
Thanks for the replies
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Gunsbee
Sep 7, 2015 07:10 PM
andy74
Sep 3, 2015 08:41 AM
