Quadrajet accelerator pump colors
Old Sep 13, 2012 | 05:28 PM
rhalpin20's Avatar
Car: TA
Engine: 5.7 CCC
Transmission: Manual
Axle/Gears: 3.70
I cant find any info regarding the different pump colors. I'm almost positive there has to be a difference?
Old Sep 13, 2012 | 05:49 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Quadrajet accelerator pump colors
I don't know about that but I do know the new ones are junk. They are so thin compared to the old ones if my old one still works I put it back in.
Old Sep 14, 2012 | 09:39 AM
Damon's Avatar
Doesn't matter. They have used different materials and colors on the pump cup over the years. If you spend a lot of time inside QJets you'll find your favorites, but color has little to nothing to do with it.
Get a good quality rebuild kit and use whatever pump cup comes with it.
Old Sep 14, 2012 | 02:36 PM
rhalpin20's Avatar
Car: TA
Engine: 5.7 CCC
Axle/Gears: 3.70
Not the cup, as that is the piece of material that makes the seal, right? i'm talking about what the cup attaches to... i just cant think of the name at the moment.
Old Sep 14, 2012 | 03:12 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
No difference that I'm aware of. Are you thinking that perhaps one color pump has more squirt than another?
Dang.....I remember when the pump cup seal was a leather band backed up with a coil spring.
Old Sep 15, 2012 | 09:22 AM
Damon's Avatar
The pump plunger assy. is what you're thinking of. Use the one that's the same length as your original. There were long ones and short ones. Most carbs take the short one.
Old Sep 17, 2012 | 02:31 PM
rhalpin20's Avatar
Car: TA
Engine: 5.7 CCC
Axle/Gears: 3.70
I understand the difference in length but there has to be a reason that there are different colors...
Old Sep 17, 2012 | 03:39 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
It might have something to do with the type of lip seal (cup) that the pump uses.
http://quadrajetparts.com/quadrajet-...yles-a-12.html
Hmmm......maybe not.
Infested
May 22, 2018 11:56 PM
BewleyBizzIROC
Sep 7, 2015 08:05 PM
LT1Formula
Aug 20, 2015 09:36 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
