Mechanical Pump as regulator?
Old Oct 17, 2012 | 12:33 AM
The Eager Teen's Avatar
Car: 1985 Trans Am
Engine: 1990 Corvette L98 w/ ported 081s
Transmission: Stock Non-WC T5
Axle/Gears: 9 bolt w/ discs
Hey guys,
The block I have has no hole for the fuel pump pushrod plus the cam has no extra lobe.
So I'm about to set up my electric pump. It's rated at 7.5 psi & 100 GPH. I was wondering if, since the mechanical fuel pump (which I have mounted on the block right now) is internally regulated and has all the provisions for the return line and output for the carb hard line, would it be suitable as a fuel pressure regulator? Or will it not regulate properly because the pump isn't being actuated by the pushrod?
Old Oct 17, 2012 | 05:06 AM
82RZ's Avatar
Car: 2000 SS Camaro LS1
Engine: 347 cu in mild mods
Axle/Gears: 3:42 or 4:10 depends on what I'am d
Re: Mechanical Pump as regulator?
Originally Posted by The Eager Teen
Hey guys,
Neither a mechanical or electric pump are designed to reguate. Its a nice thought but the mechanical only has a diaphram to pump fuel - no regulation of any kind.
Old Oct 17, 2012 | 07:21 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Been using mine like that for several years.
https://www.thirdgen.org/forums/carb...regulator.html
I've since gotten rid of the baby fuel regulator shown in the post, along with the plastic fuel filter (which I just used so I could verify the flow). Car's gotten several tens of thousands of miles since 2007.
...I've also, of course, routed all of my electric cables correctly-the photo was taken before I cleaned everything back up after re-installing the metal fuel lines.
Old Oct 17, 2012 | 09:19 AM
Damon's Avatar
A mechanical fuel pump regulates itself, true, but can't regulate fuel being forced through it. If you were to apply fuel pressure to it you would find that at around 1 PSI the series of one-way valves inside it would unseat and fuel would flow through it unobstructed above that pressure.
Get a real regulator and use it.
I also don't like using low pressure electric "helper" pumps as the only pump in the system. They have a hard time holding 6 PSI at the carb pushing only 7 PSI from way back at the tank. The force of acceleration acting on the fuel in the lines is more than it can work against and you'll often find fuel pressure dropping off pretty dramatically up by the carb when you nail it in the lower gears.
That's why you start with a pump that can feed more than the engine needs and then regulate it down to the needed pressure just before going into the carb.
Old Oct 17, 2012 | 10:18 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Depends if you're talking about a pump with a return line or not.
Old Oct 17, 2012 | 12:24 PM
Car: 1985 Trans Am
It has a brand new Mechanical Pump with a return line.
theshackle
Mar 5, 2017 06:37 PM
evan555222
Sep 20, 2016 02:51 AM
fbirdroller
Sep 2, 2015 10:27 PM
evan555222
Aug 22, 2015 07:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
