Holley 570 vs 600
Old Nov 21, 2012 | 05:31 PM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Holley 570 vs 600
Hey everyone, I have a Holley 570 CFM dual feed (80570) as well as a Holley 600 CFM 4160, for my 305. I've always been a fan of the 570 but I'm looking for some personal accounts between the two. Which do you prefer?
Old Nov 21, 2012 | 08:07 PM
hdavis2005's Avatar
Car: 1992 Camaro RS
Engine: 3.1 MPFI to 305 carb
Axle/Gears: 323
Re: Holley 570 vs 600
I have the 600 on my 305. Works great so far.
Old Nov 26, 2012 | 01:35 PM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
I have the 570 currently on my 86 T/A. I have used the 600 in the past but I feel that it is a little too much for a 305 engine. Also I like the fact that the 570 already has the secondary spring quick change kit, it comes with the clear sight plugs for setting float level, the finish looks nicer, no need to worry about proper fuel delivery to the secondary bowl through the tiny cross over tube and I just prefer center hung bowls due to having messed with double pumpers a lot.
Old Nov 26, 2012 | 03:18 PM
ChrisC's Avatar
Thanks Bestracing for as well confirming every reason why I like the 570 better. I especially feel that the 570 is the perfect 'amount' of carb as opposed to the 600 being a bit over kill.
Old Nov 26, 2012 | 03:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Since a stock 305 can only realistically use around 400 CFM, I don't see any difference between using a 570 or 600. Especially since they're both vacuum secondary.
Old Nov 27, 2012 | 06:52 AM
bestracing's Avatar
Engine: Broke - 350
I agree that there isn't much difference between the two in that aspect but I have had both on my 86 and the 570 was just a little more responsive on the track. For me, it's mostly that the 570 is more tuner friendly out of the box than the 600 since it is already equipped with quick change features and reusable bowl gaskets and since I show my car more the bright finish is better looking than the dirty yellow finish.
Old Nov 28, 2012 | 02:35 PM
five7kid's Avatar
Originally Posted by bestracing
I agree that there isn't much difference between the two in that aspect...
It was "that aspect" to which I was responding. To wit:
In "that aspect", the 570 is overkill.
Old Nov 29, 2012 | 07:40 AM
bestracing's Avatar
Engine: Broke - 350
We agree on this
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
makaveli09
Sep 15, 2015 10:43 AM
