afr head selection help!!
Old Dec 15, 2012 | 02:28 PM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
ok guys im in the process of ordering some afr heads for my car, it was originally a 350 tpi but got rid of the whole system and swapped to carb. i know there is like 4 part numbers which are 1034, 1040, and 1041. i have the performer rpm intake manifold so which one would be the correct heads to buy? please help so i can order these bad boys!
Old Dec 15, 2012 | 02:37 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: afr head selection help!!
1034 is straight plug
1040 is angle plug
1041 is angle plug with 87 and up intake mounting angle.
1034 will work with a pre 87 intake
so will 1040 but you might have header clearnce issues with the angle plugs
1041 will need a 87 up intake and again might have header issue
Old Dec 15, 2012 | 02:50 PM
robg91z's Avatar
Engine: 350ci TPI
so the 1034 would be my best bet? I'm gonna run hooker shorties for a while and upgrade later
Old Dec 15, 2012 | 02:52 PM
Car: 1971 Camaro
Engine: 427
If your intake has the pre 87 bolt angle then yes.
Old Dec 15, 2012 | 02:53 PM
robg91z's Avatar
Engine: 350ci TPI
ok thanks alot !
Old Dec 15, 2012 | 08:14 PM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
If you are ordering from AFR, get the heads milled to bring your compression up and it is worth upgrading to 7/16" studs now. Then, a real cam and you are ready to go!
Old Dec 16, 2012 | 11:59 AM
robg91z's Avatar
Engine: 350ci TPI
if i order from online and i add the upgraded valve springs , will they install them or will they come seperate? or would i have to call them first to see if they will installed them ?
Old Dec 16, 2012 | 12:20 PM
robg91z's Avatar
Engine: 350ci TPI
would that be the .008 or .006? how much of a price difference would that be , in there website it doesnt say anything on price
Old Dec 17, 2012 | 06:59 AM
pancherj's Avatar
Car: 1990 IROC
Mine had the stud upgrade and better springs (all installed by them) and 60cc combustion chambers. Tell them you want the 60cc chambers and they will figure how much to mill off. I think the cost for that was around $100.
Old Dec 17, 2012 | 07:26 AM
Car: 1971 Camaro
Engine: 427
Just call them.
evilstuie
Jan 9, 2020 08:29 PM
92projectcamaro
Jan 18, 2016 08:00 AM
z28guy134
Sep 1, 2015 11:50 PM
89mulletbird
Aug 12, 2015 07:08 PM
