Cowl hoods and carb sealing *NOW WITH PICTURES*
Old Jan 23, 2013 | 09:15 AM
  #101
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Cowl hoods and carb sealing *PICTURES REQUESTED*
Originally Posted by jhainer
well i went out last night. checked on putting the cake pan under the carb but there will be more issues with that also. (fuel lines) so for me. I would have to incorperate the fuel lines into the air box. couple an fittings and a bulkhead fitting. but it will clear the valve covers. and i think it will clear the distributor. in the pics you can see the offset works at getting it to the hole. but also the aircleaner it too tall the hood will not close. so maybe a smaller filter element will help with that the pic where most of the aircleaner is in the hole i still had enough room to put my hand under the hood with it closed about 4 inchs before it closed. this aircleaner use to work with my old intake with this intake if i put a 1 inch carb spacer on (nos plate) the carb hit the hood without a aircleaner.
Add a dual return spring to that carb!
Old Jan 23, 2013 | 10:12 AM
  #102
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
my drop is 3/4. my concern is the extra 1 inch clearance over the top of the carb. i have a smaller air cleaner one inch thick no drop and only 9 inch around it fits in the hole no problem and doesn't hit the hood. but it's to small it restricts the 930 cfm the carb i have is a 850 jetted to 930 with smoothed blades and I honestly don't know what is all done to it. i sent it out to a speed shop in the area and told them to rebuild it the same way it is now settings wise because it was my father in laws race carb for this motor. theres no choke or anything on it. this is with no air cleaner looks like total i have about 3 inchs
Attached Thumbnails Cowl hoods and carb sealing *NOW WITH PICTURES*-774277_10200421901613009_661172987_o.jpg
Old Jan 23, 2013 | 10:23 AM
  #103
skinny z's Avatar
All my vehicles (502 w/Holley, 355 w/ Barry Grant, 305 w/ Holley) have an 1 1/2" drop and there's no contact with the carb so maybe that'll be the same for you. Clearence for the float adjustment nuts, the fuel lines and the throttle is sufficient.
What I don't like is that with the 1 1/2" drop, it puts the lid of the air filter case within about 3/8" of the choke horn. I guess that's not a problem with no choke horn though.
As for air filters. if you run a K&N, a 14 x 3 is about as small as you'd want to go before the filter starts to restrict flow. Traditional paper elements are less forgiving and need to sized larger. An 11 x 4 offers the same filter area but the base on an 11" has zero drop so there may be other complications when the lid will be about 5" higher than the carb flange.
Old Jan 23, 2013 | 10:28 AM
  #104
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Originally Posted by skinny z
My 502 has a 1 1/2" drop as does my 355 and there's no contact with the carb so maybe that'll be the same for you. Clearence for the float adjustment nuts, the fuel lines and the throttle is sufficient.
So you know where i have been for awhile. I thought going to the 4 inch cowl would solve most of this but nope it didn't but looking at your base it looks like i might be able to get it low enough to fit under the cowl Is yours offset at all?
Old Jan 23, 2013 | 10:29 AM
  #105
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
had one lost it on the last rebuild just haven't gone and got another. the car hasn't been driven since the last rebuild.
Old Jan 23, 2013 | 10:33 AM
  #106
skinny z's Avatar
I failed tech at the drag strip because of one return spring. It had completely slipped my mind to re-install it. I was able to get another from a fellow racer.
I also got nailed for no locking dipstick on the trans but I was given an exemption if I taped it up tight. I always have a roll of electrical tape with me!
Old Jan 23, 2013 | 10:35 AM
  #107
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
LOL it's never been down the strip yet
Old Jan 23, 2013 | 10:42 AM
  #108
skinny z's Avatar
.... yet
....yet
Old Jan 23, 2013 | 10:50 AM
  #109
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
wife just ordered the 18X3 cake pan can't find locally. also sent her the 1 1/2 drop base to order. once the base is on and i know it fits under the cowl then i can put the offset in by attaching the cake pan offset. then trim the top of the pan to fit the hood contour then i should be all set for a gasket. now thats the plan but we will see how it goes
Old Jan 23, 2013 | 10:56 AM
  #110
skinny z's Avatar
Well, you'll be miles ahead of me in the fabrication department. I've made a commitment not to spend any time on the hotrod until spring. Too many other projects half finished. It's a good thing I don't consider the hours I spend researching and posting as "time spent on the hotrod"!
Good luck and be sure to post up with your progress.
Old Jan 23, 2013 | 11:12 AM
  #111
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
this year's projects for the hotrod are the cowl seal that we have been working on . forth gen seats leather, and a sub box that fits the hatch area. but it will also hold the 2 Nos bottles and a single alpine 10 that i have but have an area that is lit up with led's that will shine through .the attached photo so it will be lit up from behind i have to put plexiglass behind it to hold the letter cut outs . I have 2 one for the Iroc and one for the wall of the garage.
Attached Thumbnails Cowl hoods and carb sealing *NOW WITH PICTURES*-550941_4751346184490_1589578568_n.jpg   Cowl hoods and carb sealing *NOW WITH PICTURES*-545822_4735447787040_2070022917_n.jpg
Old Jan 23, 2013 | 11:16 AM
  #112
skinny z's Avatar
Just saw this post. The big block TA has a glass hood the completely open on the underside so an offset wasn't needed. It needs one of the All Star air pans posted earlier.
The dropped base fit with no issues than I can recall. (It's been 6 or 7 years).
Old Jan 23, 2013 | 11:22 AM
  #113
skinny z's Avatar
Nice artwork.
The IROC that I had prior to this coupe had a pair of 10" subs with a big Jensen amp and used the trunk well as an enclosure. Not uncommon I would think and quite effective. The coupe has a simple factory arrangement with an aftermarket head unit and speakers (no subs although they're ready to go should the need arise!). I usually listen to the engine when I drive.
Old Jan 23, 2013 | 11:27 AM
  #114
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Me too. motor sounds drown out the radio. more for show is the reason i have the radio and sub box in there i have a box for a 4th gen in there now but i want to incorperate the sign with led's behind it so i will redo it i also want to put in a dual bottle bracket to hold the bottles and have the bottles repainted to match the car. i have a nx kit and an extra nos bottle so a blue and white bottles won't look good together but 2 orange bottles will in this post you can hear the motor Post#8 is the video.
https://www.thirdgen.org/forums/engi...again-big.html
Old Jan 23, 2013 | 11:35 AM
  #115
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
I missed this post.
Excellent pictures (which I've copied below). Another "cake pan" special. I've also attached a link to the McMaster Carr bulb seal that's needed to go around the cake pan rim.
http://www.mcmaster.com/#catalog/119/3456/=l5ryax
This is shaping up to be a "how to" thread rather than a request for information.
That McMaster part is what I was talking about when I post a link to that company that made universal trim seals. I like these better because they are of a sealed foam cell design. It's just a personal preference but I just don't like the open cell foam and that seal has a more "Factory" clean look to it.
  #116
Car: 1971 Camaro
Engine: 427
Good to be safe on the street too!
Old Jan 23, 2013 | 11:38 AM
  #117
skinny z's Avatar
....in this post you can hear the motor
That's an understatement. Your sure won't be able to sneak up on anyone.
Old Jan 23, 2013 | 11:41 AM
  #118
skinny z's Avatar
I agree with you on that one. I prefer the rubber seal too.
Once I start to fabricate this thing in earnest, I'll end up getting some the MaMaster Carr stuff. They have several sizes to choose from so finding one the fills the gap shouldn't be too difficult.
Old Jan 23, 2013 | 11:42 AM
  #119
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
I liked the seal you sent that looks like a rubber seal like the factory would use
Old Jan 23, 2013 | 11:45 AM
  #120
skinny z's Avatar
It'll fit onto the edge of the cake pan too. Very slick.
Old Jan 23, 2013 | 11:47 AM
  #121
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
the neighbors called the cops on me over teh weekend i took it for a small test drive down the street and i guess it rattled things in there houses i really dont know if it did or not but 4 neighbors called I laughed about it. i have one neighbor that autocrosses and runs road atlanta. with ls1 based bmw another neighbor that runs his race bikes up and down the street at about 50mph and no one calls on them but i idle down the street and and back and get 4 calls. It must be loud. the dynomax race bullets don't help sound to much . I might have to add a new exhaust to the project list this year
Old Jan 23, 2013 | 11:49 AM
  #122
skinny z's Avatar
Like I said, I prefer the sleeper look, in appearence and sound.
Old Jan 23, 2013 | 11:50 AM
  #123
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
in the video it looked to just clip over the edge so if it does it would make it real easy to make work
Old Jan 23, 2013 | 11:54 AM
  #124
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Me too but the big block didn't like the 2 1/4 inch exhaust the car shook itself apart with 13.5 compression i couldn't get the air out fast enough through the 2 1/4 so i went to the 3 inch and didn't think it was going to be as loud as it is. photo attached is the same car different wheels and exhaust it looks completely different.
Attached Thumbnails Cowl hoods and carb sealing *NOW WITH PICTURES*-1986-iroc-z-658
Old Jan 23, 2013 | 11:55 AM
  #125
skinny z's Avatar
You can see in the pic below how it would fit onto the lip of the pan. Much like some weatherstripping.
Attached Thumbnails Cowl hoods and carb sealing *NOW WITH PICTURES*-mcmaster-carr-bulb-seal.png
Old Jan 23, 2013 | 11:58 AM
  #126
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Cool that would make it real easy since the pna is going to have different size lip all the way around. then use some wrinkle paint to paint the pan it should look pretty stock .
Old Jan 23, 2013 | 12:00 PM
  #127
skinny z's Avatar
Checkout their catalogue for the different sizes available. You should be able to find something that fits and looks OEM.
Old Jan 23, 2013 | 12:03 PM
  #128
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
my main concern is still the distributor but i think i might have enough wiggle room to get around it. I see opening and closing the hood 1000 times in my near future. while test fitting
Old Jan 23, 2013 | 12:07 PM
  #129
skinny z's Avatar
At 18" across, that cake pan is pretty big. I'm not sure have the room considering that a 14" filter housing is almost on top of an HEI. I have a small cap distributor so the added clearence will be a bonus.
Maybe you should have ordered the offset base (with the 1 1/2" drop) to help with fitment. It's designed specifically to clear the HEI.
Edit: Then again it would probably throw off the cowl opening alignment.
Old Jan 23, 2013 | 12:14 PM
  #130
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
I thought the same thing . I need the offset about 3/4 so i have to rotate the offset to make it workyou know your probably right i probably need the 1 1/2 drop with offset
Old Jan 23, 2013 | 12:17 PM
  #131
skinny z's Avatar
This is why I'm going to try and build a prototype out of spare parts. Once I have the fit established, I'll get to searching the aftermarket to see what's available.
I'm pretty sure I'll have to build and use my own 3/4" offset to get the air filter centered. I haven't seen anything that comes close. It's 1 1/2" to clear the HEI or nothing.....so far anyway.
Old Jan 23, 2013 | 12:43 PM
  #132
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
I needed parts to fab this up so atleast now i have what i should need I think i will have to use and 3/4 offset with the 1 1/2 drop and put the cake pan on the intake under the carb
Old Jan 23, 2013 | 12:46 PM
  #133
skinny z's Avatar
That all sounds good but keep in mind you'll have to build your 3/4" offset. I've found nothing that's suitable.
Old Jan 23, 2013 | 12:50 PM
  #134
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
I wonder if i could cut off the outer ring area of my offset base move that ring down the 1 1/2 inch make 3 tabs to weld it in that position and see if it would work that might be an idea also . that way i have teh offset and the 1 1/2 drop
Old Jan 23, 2013 | 12:55 PM
  #135
skinny z's Avatar
That may take more than a few tabs. It seems to me that you'll have to fill the resulting gap with some sheet metal, unless you have two bases to work with as I have in the picture below. If you look closely, you can see the offset. A little more trimming and I'll be 3/4" with room to spare.
Old Jan 24, 2013 | 02:06 PM
  #136
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Cake pan is here now waiting for the drop base drop base is in Knoxville should be here tomorrow
Old Jan 26, 2013 | 12:24 AM
  #137
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
Well everything showed up today once i got off of work I tested the 1 1/2 drop base it worked fine. cleared everything except there was no offset. so i cut the center ring out and ground off a lip on a different 9 inch base offset it and screwed it to the drop base put on my air cleaner and tested the fit. hood closed for the first time with my14X3 air cleaner. so the next step was to cut out the cake pan to put the air cleaner base on the cake pan. so I cut out a a hole in the center of the cake pan and attached the cake pan to the drop base. test fitted the whole unit on the car. no clearance issues. except for trimming to fit the hood when closed. I should have about 1/2 inch in the front and about 2 inchs in the rear. heres my progress so far.
Attached Thumbnails Cowl hoods and carb sealing *NOW WITH PICTURES*-740033_10200440069467194_115101702_o.jpg   Cowl hoods and carb sealing *NOW WITH PICTURES*-773593_10200440063667049_188137008_o.jpg   Cowl hoods and carb sealing *NOW WITH PICTURES*-798341_10200440072307265_2132977410_o.jpg
Old Jan 26, 2013 | 12:25 AM
  #138
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
some more
Attached Thumbnails Cowl hoods and carb sealing *NOW WITH PICTURES*-774767_10200440066107110_2028793885_o.jpg   Cowl hoods and carb sealing *NOW WITH PICTURES*-775695_10200440061146986_809526748_o.jpg
Old Jan 26, 2013 | 07:26 AM
  #139
skinny z's Avatar
as we expected it would...
expected that too...
excellent!...
that's a little more clearence at the rear than I would have anticipated..
Nice. I only wish I had done it first! As far a seal goes, do you think the Moroso foam installed more or less as the Monte article would work (providing you install it with the taper needed from front to rear) or are you inclined to try the bulb type rubber seal? A 2" gap is a fair bit to seal up. Maybe a deeper cake pan that can be trimmed so the whole works is within 1/2" of the hood would give the desired result. Then the rubber seal can be used.
That's an excellent bit of work. Like I said, I wish I had mine done too but the shop isn't heated and we're into our traditional January cold spell. -30 the other day and the shop is a no-man's land.
Old Jan 26, 2013 | 11:52 AM
  #140
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
once it is cut down the front of the pan should about a 1/2 inch the rear should be about 2 inches leaving enough room for the seal either seal accually. i have to slowly trim it down until the hood closes the way it sits now the hood doesn't close with the cake pan but does close without it with just the air cleaner which it didn't do until i got the drop base you suggested. to be honest it needs some more work cleaning it up. almost like you said its a prototype. but nothing a grinder and a welder can't fix. the cke pan seems to be aluninum and so does the base which makes welding for me imposible.
Old Jan 26, 2013 | 01:21 PM
  #141
skinny z's Avatar
I came across aluminum with the 9" base that I'm using. Considering that it wasn't my intention to weld anyway, that's not much of an issue. One of my engineering buddies, who's also a racer has suggested using an epoxy to hold the works together. I like the idea over nuts and bolts or rivets in that if one of the fasteners ever comes apart then it may get drawn into the carb. That would be unpleasent.
I'm happy to see some results with this whole experiment. (There may be a market for this when we're done!)
Old Jan 28, 2013 | 09:45 AM
  #142
bestracing's Avatar
Engine: Broke - 350
Nice!!
Old Jan 31, 2013 | 09:27 AM
  #143
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
i took a few pics of it off of the car with some rubber seal on it. it is now cut down to fit under the hood fine. this is kinda a working prototype. i need to get it welded up so i can remove the nuts and bolts. or atleast find all matching new bolts with poly locks and locktite. i don't want them rattleing off and into the carb. when it is all put together you don't see any of the cuts but i know there there. so i would love to weld them up and then grind smooth for a more cleaner looking aircleaner.
Attached Thumbnails Cowl hoods and carb sealing *NOW WITH PICTURES*-842884_10200471823021013_423996085_o.jpg   Cowl hoods and carb sealing *NOW WITH PICTURES*-376213_10200471822781007_1345565919_n.jpg
Old Jan 31, 2013 | 09:35 AM
  #144
skinny z's Avatar
That looks great!!
A couple of questions: Whose dropped base is that? It has a nice form. Certainly a better design than the unit I'm cutting up.
Which seal? Is that from the McMaster catalog? It looks right at home in an OEM sort of way.
Well done.
Any pics with the filter in place? I'm curious as to what kind of space there'd be between the filter lid and the carb. You certainly don't want a restriction there.
Old Jan 31, 2013 | 09:45 AM
  #145
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
That looks great!!
Well done.
part number through summit pro-66808 $33.95
i had it 2 hrs before i cut it one thing is when you cut it for the offset you end up cutting off the carb flange so when you go to mount the aircleanerteh base hit my bowl level screws so i had to buy a carb air cleaner spacers
Spectre/Air cleaner adapter and riser kit
Part Number: 4950
the one i used is the front row left one. that raised it up enough to fit over the carb. the gasket is one a buddy brought over. not sure if i am going to use it or not i have to cut the whole gasket to make a slit for it to slide over the cake pan. i was looking at the site mentioned and it's like 7 bucks for the seal so i might just do that and be done with it or buy the chevelle gasket and be done and have the oem look to it .
Old Jan 31, 2013 | 09:56 AM
  #146
skinny z's Avatar
I have a base from a 9" filter case to use as the "offset ring" so the carb flange portion will remain intact. Hopefully that'll eliminate the need for a carb spacer. (I had thought you were doing the same too though).
I like the looks of the seal in the catalog. It has the split along it's length so the installation should be simple. The only thing to determine is the "height" of the seal itself.
Old Jan 31, 2013 | 10:22 AM
  #147
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
i had a 9 inch one also but the flang where it rests on the carb was about a 1/4 inch where as the drop base flange was about 1 inch so i had to make up the difference.
Old Jan 31, 2013 | 10:26 AM
  #148
skinny z's Avatar
Underdstood.
Old Feb 23, 2013 | 09:03 AM
  #149
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i made a prototype, lol. im gonna duplicate it out of aluminum and tig weld it together. still need to get a seal. found out i had room for a 4 inch filter. just ordered a 14x4 filter with the extreme lid.
Old Feb 23, 2013 | 09:08 AM
  #150
skinny z's Avatar
That looks pretty good. If I had the open cowl that's the route I would have taken too.
This seal looks like it would work for you.
