Cold start high RPM's
Car: 1984 Trans Am
Transmission: 700r4 automatic
hey guys i have a 1984 trans am with the 5.0 engine my question is when i start my car up in the morning or afternoon even when its cold or hot when i start it the engine revs up to about 2200 rpms and i have to hit the gas to lower it usally takes about 3 or 4 minutes to drop down to 700 rpms is that normal please help thank you
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
That's the normal choke/high idle function, but the RPMs are a little too high.
Is the underhood emissions sticker still on your car? It gives the proper RPM level. I could go out and look under mine, but it's dark and cold out there (and my car has an LS1 in it now... ).
Car: 1984 Trans Am
Re: Cold start high RPM's
It's to dark and cold to here to check and lucky you I havnt had the time or money to upgrade mine yet
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
you can lower the fast idle speed by turning the screw that's buried up in the choke linkage. 1200-1500 is a good rpm to shoot for.
Car: 86 Camaro
they want that kind of rpm to get the converter up to temp as fast as possible.. but if cold start emissions aren't a concern, there's no need to run it that high.. notice that it also says to set the timing at 6 BTDC but these smog choked engines really only wake up with around 10 BTDC....
