500 cfm
500 cfm
I recently purchased an Edelbrock 500 carb. I am wondering if I will need to get an adapter plate to use it on my stock manifold. I plan on getting an edelbrock performer RPM intake later. I just really need to get rid of the quadrajunk that is on it now. Thanks for all y'all's advice in advance
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 500 cfm
The best advice you'll get is to fix whatever's wrong with the Quadrajet since it's a vastly superior carb to the Edelbrock.
Second best would be to get a Holley DP instead of the Edelbrock. Wait until you've changed the manifold instead of running an adapter either way.
Re: 500 cfm
I already have the edelbrock. the q-jet isn't opening the secondaries, I believe it has to do with the vacuum diaphram for them. I think the other issue with it is the idle control solenoid (that is a guess at what it is called) it is on the D/S front corner and the linkage right behind it. the issue is no matter how much I adjust the actual idle screw or adjust the solenoid my idle is still all over the place. like going from 470-610 rpm. I don't know much about he q-jets, but over Christmas I rebuilt it and it ran better for a couple of weeks. Then last week it started doing this. I have had Edelbrocks in the past and have gotten good performance out of them.
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: 500 cfm
sreZ28
Oct 22, 2015 08:21 AM
Dragonsys
Sep 25, 2015 03:51 PM
