350 build
Old Feb 4, 2013 | 03:21 PM
Nickschfr's Avatar
350 build
Hi I'm new to this forum and I just wanted to know what kinda power I should be expecting with this combination:
Iron vortec heads
Edlebrock preformed intake
Holley 570 street avenger
280h comp cam
Flat top pistons
Hooker short tube headers
I know the heads have been machined but I don't know exactly how much. I do know that my 475 lift isn't hitting and that's about as much as I know. I've head of people getting 370 hp and 400 lbs tq with these heads but they have had work done to them
Old Feb 4, 2013 | 03:46 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: 350 build
Which vortec heads and what cid?
Old Feb 4, 2013 | 04:08 PM
Nickschfr's Avatar
Re: 350 build
350, they are 906 iron vortecs. After doing some research I found out they are great stock heads, I thought I was stuck with swirl port until I looked at the intake bolts.
Old Feb 4, 2013 | 06:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you sure about the lift of the cam? A 280H should be .480" lift.
You're a little under-carb'd and under-intake'd. A 600-650 CFM carb would be better, and a Performer RPM is more suited to the cam (although it's not that great of a cam).
You're probably in the 350 HP range. With a better cam, intake, and carb, 400 should be a cake walk.
Old Feb 4, 2013 | 06:27 PM
Re: 350 build
350, my mistake...Not much room for improvement on the vortecs. Maybe some polishing of the intake port short turn. I agree with a bigger carb.
Old Feb 4, 2013 | 07:09 PM
Nickschfr's Avatar
Re: 350 build
So basically if I wanna get any real improvement I should look at some new heads? I don't have the cash now but in the future I was looking at the afr 195 eliminators and a 670 carb, after I build my tranny and rear to hold more hp
Old Feb 4, 2013 | 08:07 PM
rs89todd's Avatar
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
Re: 350 build
400 is good street horse power, get a carb, rpm air gap intake and LONG tube headers, if you have a dremel port match the exhaust ports on both head and header
Old Feb 4, 2013 | 08:32 PM
five7kid's Avatar
Originally Posted by Nickschfr
... a 670 carb...
Personally, I have no love for those Street Avenger carbs. Or vacuum secondary carbs in general, for that matter.
With the right stall, a double pumper will do much better than a VS carb. A 650 will support the power you're talking about just fine.
The weakness of the Vortec heads is the exhaust ports. That's why I'd say get a better cam as well. One with a little more exhaust duration to help them do what the intakes do.
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
