92 need fuel return help
Old Feb 26, 2013 | 03:51 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Ok so just got my buddys car running 92 camaro tbi swap to 350 carb. Put in a holley regulator stock intank fuel pump car runs great but im getting fuel coming out of my return line which i left open and untouched can i just plug the return?
Old Feb 26, 2013 | 05:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Would you rather spend $50-$75 more for a regulator, or replace $125 in-tank pumps every few months?
That Holley regulator is the wrong thing for this application. The in-tank pump requires a constant flow of fuel to keep it cool.
Get a return-style regulator like a Mallory 4309 (more expensive) or Jegs 555-15909 (less expensive but adequate). That means you'll be using the return line again. That should stop the leak.
Old Feb 26, 2013 | 07:04 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Re: 92 need fuel return help
well any way i can take the fuel pressure gauge out of the holley afr and use that port for the return?
Old Feb 26, 2013 | 07:10 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
no, you have to have a return style regulator. is completely different internally then the non return style.
Old Feb 26, 2013 | 07:12 PM
travis401's Avatar
Car: 91 Camaro RS
the other option is to drop the fuel tank, remove the intank electric pump, replace it with a carb style pick up, and run a block mounted manual pump.
Old Feb 26, 2013 | 08:31 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
ok thanks guys
Old Feb 27, 2013 | 05:55 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
ok thanks guys
Sorry man, those guys are right. Doing it right can become a hassle, but it's much better than having to spend alot of money later to replace stuff, especially fuel pumps which are a pain in the rear in general.
Old Mar 25, 2013 | 08:51 PM
86mailman's Avatar
Car: 86 Iroc
Engine: 496
Transmission: 4l80e
Axle/Gears: 9" eaton posi 4:11
i have a holly red pump with a regulator. the intank pump is fried. So using the holly with the reg. Do i need to use the return line? a buddy of mine told me i could (tee) off the feed line with the return line so i dont burn my pump up. is this fact or fiction?i was also told when i take the intank pump out i have to modify the sending unit somehow.
Old Mar 25, 2013 | 09:05 PM
86mailman's Avatar
Car: 86 Iroc
Engine: 496
Transmission: 4l80e
not sure if you got my reply so here i go agian. I have a holly red pump and regulator. My intank pump is fried. So do i have to use a return line with my style of pump or can i cap it off. a buddy told me i could tee off the feed line with the return line before the regulator so i wont burn my pump up. is this fact or not? also i was told when i take the intank pump out i have to modify the sending unit somehow.
Old Mar 26, 2013 | 09:12 AM
Ozz1967's Avatar
Car: 1984 Trans Am
I would run a return, just to be safe. Electric pumps like the fuel returning as it creates a "Flow" in the tank which cools the fuel. I personally burned up 2 of the Holley red pumps and one Holley Black pump and I had the return hooked up. I scrapped them for the in-tank pump because I don't trust them to last more than a month or two. It was an expensive lesson.
Old Mar 27, 2013 | 07:34 PM
travis401's Avatar
Car: 91 Camaro RS
you still need to drop the tank and remove the intank pump to run the external holly pump. and you still have to use the return style regulator unless the pump has a built in regulator. to keep from burning the pump up.
Grant2k
Jul 10, 2018 04:01 PM
anesthes
Aug 24, 2015 08:18 PM
wayshegoes
Aug 17, 2015 12:00 PM
TEDSgrad
Mid-West Region
Aug 10, 2015 07:12 AM
Kaweh
Aug 9, 2015 02:54 PM
