speed demon 750
Old Apr 22, 2013 | 05:47 PM
NotsosleepyZ's Avatar
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
speed demon 750
now yes the carb is probably a bit large, but the article i was following used as 750 holley, first off its an 85 305, but i have bg speed demon 750, trick flow 175 heads, 268 h13 cam, 1.6 rockers, edelbrock rpm airgap, full length hedman headers, now the question: will this work with my stock ecm or am i gonna be losing gobs of power, cause that leads to a new dizzy and playing with the tranny or burning a chip(which is very unlikely).. i was waffling back and forth on a tpi kit i found for same year car and decided i wanna keep it as simple is possible so i have ended up with said carb.
Old Apr 22, 2013 | 09:32 PM
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
Re: speed demon 750
bump, nothing eh..
Old Apr 22, 2013 | 10:03 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: speed demon 750
Originally Posted by NotsosleepyZ
bump, nothing eh..
Got a pic of your carb? I'm looking for a 750 Speed Demon for my blown 400 sbc....I have a 650 Speed Demon DP on it now, which made 387 HP and 495 TQ, but I think there's more there, so I'm looking to go bigger.....Just a thought....
Edit: You could use the 750, but you'll need to jet it down, and you might lose a little power on the low end...and using it with any ECM is out of the question....you need to ditch the ECM and go with a vacuum advance distributor with the Demon...
and TPI..?? Some searching is in order....
Old Apr 22, 2013 | 10:19 PM
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
Re: speed demon 750
ill post my pic when it arrives tomorrow, ive been waiting till I got all my pieces before I posted pix lol, and on the research part that's exactly why I went with the carb almost jumped the gun and got it but learned at the last minute of the different computers, and as this one matched my year (85) it was a less desirable tpi set up so I passed. the build I followed was a superchevy 305 build you can google it I think they made 362 hp 350 torque, I went with the alternative bigger cam, thanks for the advice on the dizzy looks like I ll be hunting forums for the trick for locking the converter
Old Apr 23, 2013 | 11:39 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: speed demon 750
bump, nothing eh..
Is there a question in that block of text?
Old Apr 23, 2013 | 12:07 PM
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
Re: speed demon 750
lol
Old Apr 23, 2013 | 12:09 PM
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
Re: speed demon 750
well the question was can i keep my stock dizzy with this carb or wll the timing constrict said upgrades? other than throwing an engine light would it send the computer into safe mode or something?
Old Apr 23, 2013 | 01:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can use the stock distributor in a race-only application. Just set the total timing to 36 and go.
If you plan on driving on the street, you need a vacuum/mechanical advance distributor. With anything but a factory computer q-jet, the ECM will be braindead.
Old Apr 23, 2013 | 05:58 PM
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
Re: speed demon 750
thank you sir, thats what i figured, any suggestions on which one?
Old Apr 23, 2013 | 11:00 PM
midias's Avatar
Re: speed demon 750
I like my MSD 8360 with SS coil but there are hundreds of choices
Old Apr 25, 2013 | 05:38 PM
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
Re: speed demon 750
Old Apr 25, 2013 | 05:39 PM
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
Re: speed demon 750
Old Apr 25, 2013 | 05:41 PM
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
Re: speed demon 750
there they are all im missing is the pic of headers, and i need a gasket set for heads and intake as well as a distributor still.
Hotrodboba400
Dec 10, 2019 07:07 PM
PurelyPMD
May 5, 2016 04:57 PM
TexasMaro
Sep 15, 2015 06:50 PM
mackjar66
Sep 14, 2015 01:17 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
