Carb air cleaner for stock IROC hood? Help
Car: 1987 Camaro IROC-Z Z28
Engine: Custom Vortec 350
Axle/Gears: 3.73, Auburn Pro Series diff
I need help finding an air cleaner that will fit my stock IROC hood. I have a 350 with edelbrock rpm air gap intake, and quick fuel carb. Help pleaseeee
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Re: Carb air cleaner for stock IROC hood? Help
this one: http://www.summitracing.com/int/part...3040/overview/ fits under stock C3 Corvette hood so should fit in Camaro too. And it gives alot of airflow.
best regards
best regards
Car: 1985 Camaro SC F41
Engine: ZZ4
Axle/Gears: 3.42 Posi
Look at something with a drop base, Summit and Jegs both carry them. The Performer RPM is a pretty tall manifold, the Air Gap is probably a little higher, and if you're running a carb spacer of any size you're quickly running out of clearance under the stock hood. If a drop base air cleaner doesn't get the room you need, it might be time for a cowl hood.
This may work for you: http://www.summitracing.com/parts/afc-80550/overview/
at least it will give you a start in the right direction.
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
you have to have a drop base that has the shape for the holley dp type bowls. you also have to worry about the hei, if you dont have the smaller non-coil in cap type
I have the MSD Street Fire HEI distributor. With the coil pack located on top of the distributor cap I believe
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
L88 drop base (reproduction...cost about $50). That, combined with a 3" air filter and a lid of your choice. This allowed me to fit an AirGap with a 1" spacer and my Mighty Demon carb under my stock IROC hood. The rear of the drop base will need to be trimmed for the HEI (Not a big deal).
Not sure what the drop is on a L88 base however with an 1 1/2" drop (which is about my maximum before I get interference with the throttle spring), a 3" element and just about any lid, I get the slightest of contact with the IROC hood. That's with an RPM Air Gap intake and either a Holley, BG or QFT carb. I found the K&N Extreme lid to offer the most clearence.
Car: 1990 IROC
I am not sure of the exact drop with the L88 base, but it seems like more than 1 1/2". Before that, I tried the generic (older) Moroso drop and it was useless. It contacted the float bowls on the Demon, it hit the linkage and it had major interference with the HEI. The L88 was much easier to work with.
86IROC112
Aug 17, 2015 02:00 PM
