should i put it on?
should i put it on?
So i have a edelbrock thunder series chillin in my shop and i have a stock carb on my camaro. The edelbrock one.is.missing the butterfly flaps. Not the.choke ones. Will it run ok without them on?
Im not fixing the choke issue on the carb thats already on my car. The choke is always open. Like straight up and down. It drives fine.once its warmed up good. Im replacing the carb with tje edelbrock one without the secondary flaps. But im ganna try and buy some of course i just need to.know if.it will be ok short term
Re: should i put it on?
Ok, yeah, short term it should be just fine.
As far as that rochester goes, I'd gamble to say that the choke isn't actually working if it is open 24/7, or maybe it was just tuned to offset the fact that it is...if that's even possible.
good luck with the swap, you'll notice a difference.
If you have plans for the 350 I wouldn't bother putting any more in the 305 then absolutely necessary.
The difference I meant was how the car will run, it should be noticeably better. (at least I would hope so, considering that your choke is wide open right now)
Have you tried closing the choke? like...what keeps it open? Is it a computer controlled carb?
Any car with a carburetor will need to warm up when it's first started though, just fyi.
If i'm not mistaken, the secondary flaps you are referring to operate the secondary metering rods, just like a quadrajets secondaries. You can run the carburetor. it just won't dump any gas when you try to open it up.
Received 1,697 Likes
You may run into a few minor stumbling blocks:
Explain clearly how putting this thing on your car is a good idea.
- The Edelbrock doesn't have the same bolt pattern as the Q-Jet. It won't bolt to your car.
- The Edelbrock won't fit the stock fuel line.
- The stock air cleaner won't fit the Edelbrock.
- The Edelbrock isn't computer-controlled, so the whole system that controls among other things the ignition timing, won't work right. The car won't run properly and will get HORRIBLE gas mileage as a result.
- The Edelbrock won't have any of the correct linkage for hooking up to your transmission if it's an auto, so you'll have to go out and buy that, or you'll burn up the transmission.
- The Edelbrock is missing parts; meaning, it's GUARANTEED not to work right.
- Your choke being open, matters for about the first 5 minutes after you start the car cold; after that, that's how it should be. How do you even know that the Edelbrock's choke works?
