going to carb
Old Jan 11, 2015 | 11:43 AM
sgp0511's Avatar
Car: 1988 Firebird
going to carb
So im in the process of doing a engine swap in my 88 bird. going from 350 tbi to 305 carb. at first I thought i was going to stick with tbi since i basically have everything to do it, but after pulling out the old engine yesterday, and seeing the harnesses condition and the overall condition of the wiring in the dash and under the hood, id rather not deal with the headache and just do it simple old school carb and hei distributor. the 305 i have has a quadrajet computer controlled carb on it. I know obviously i cant use the computer controlled carb, so what all mechanical carb will fit on the quadrajet intake? basically its an all stock 305, im not really looking for performance, just stock. also i plan on just using a block mounted fuel pump. I know i will remove the electric pump in tank and just run a rubber fuel line in its place.
Old Jan 11, 2015 | 03:10 PM
Night rider327's Avatar
Car: 1988 Camaro
Re: going to carb
You pretty much have it down.
I would not use just a long rubber line to replace the pump though, what I did was used a length (to get same length as elec pump was) of 3/8" steel hard line, and joined it to the pickup with a short length of rubber and a couple clamps.
For your carb.. Any 1970's type Q jet will fit, edelbrock carb sometimes will work on Qjet intakes..
You for sure can run an edelbrock or a holley carb on a QJet (spread bore) intake with a spreadbore to square bore adapter plate
Old Jan 12, 2015 | 07:07 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: going to carb
you need a 70s vacuum hei too and a way to control lockup on the 700, there is a sticky in this section you can read
Old Jan 15, 2015 | 11:38 AM
1982Z28Modified's Avatar
Car: 1982 Z28
Engine: 5.0L
Axle/Gears: Ten Bolt Disc Posi 3.23
Re: going to carb
If the 305 has its stock intake, I would place a Holley 4175 spreadbore on it. It's designed as a bolt on replacement for the q-junk. You will also need a new distributor. Advance Auto has a nice MSD for around 100.
Old Jan 16, 2015 | 08:57 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
Re: going to carb
you have a link all i am finding is like 235. ign stuff has gone up alot lately, i got a mallory at summit i think maybe 8 or 10 years ago. it was like 100-120, now its 200 for the same exact dist.
http://shop.advanceautoparts.com/p/m...15034|L3*16062
when i first did my conversion i went to the junk yard and got a vacuum advance out of an old chevy for like 5 bucks. just have to get a good new cap and rotor and replace it.
Old Jan 16, 2015 | 12:02 PM
Car: 1988 Camaro
Re: going to carb
He's probably talking about a MSD street fire http://www.summitracing.com/parts/ms...make/chevrolet
Old Jan 16, 2015 | 12:29 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
Re: going to carb
that looks like a good one, the adjustments look easy to get to, thats why i like my mallory one. msd is good quality too.
Old Jan 16, 2015 | 12:41 PM
sootie007's Avatar
Car: 91 RS VERT
Engine: 305 9.67 2.02 58 cc 282 480 108 LC
Axle/Gears: 4.11 POSI
Re: going to carb
http://www.ebay.com/itm/SBC-BBC-CHEVY-65K-BLACK-HEI-DISTRIBUTOR-6501-B-/331158413404?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4d1a94605c
Dist under $50 , connect two wires and your done ...this is the one I used. My carb conversion thread - a little different than yours but lots of good info , p/ns etc https://www.thirdgen.org/forums/carb...s-305-tbi.html
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
