Stalling
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Stalling
Should of kept it tpi lol
Check idle speed and afr adjustment on the idle circuit.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Stalling
Check the basics, timing, AFR, idle settings and ignition components. Report back what you find
Car: 1991 camaro z28
Engine: 5.7
Re: Stalling
I still have the efi just tucked away so if i ever want to go back i can always go, but as for the carb don't have a lot of time to mess with it till Saturday but after that morning i will let you know everything. I did hear that out of the box the street demons run rich
Re: Stalling
Is your float level set correctly. Read Sofa's Holley Tuning Sticky: https://www.thirdgen.org/forums/carb...ey-tuning.html
Engine: 5.7
Re: Stalling
I had someone look at it today and said my choke is sticking and that is whats causing it to flood how do i fix this i'm new to carbs
Engine: Lb9
Transmission: M20
Re: Stalling
It’s been along time since I’ve fooled with a carb but.
Sounds like a mechanical hang up not the electric choke pull off.
The setting on the side adjust the amount of time it takes for pull off of the choke I don’t think it’s for the choke adjustment. The linkage might be bound on the high idle cam side of the choke .
Engine: Lb9
Transmission: M20
Re: Stalling
The linkage can be pinched with the air cleaner housing. They recommend pn 786004
Air cleaner base to clear the choke linkage.
Engine: Lb9
Transmission: M20
Re: Stalling
There are two primary adjustments: the fast idle adjustment screw and the choke timing. The fast idle adjustment screw controls how far the primary butterflies are open when the choke butterfly is closed or partially closed. It controls how fast the engine will idle during cold engine warm up. The fast idle adjustment screw is located on the bracket that is screwed to the throttle shaft, behind the choke housing
Engine: Lb9
Transmission: M20
Re: Stalling
Take out another machine screw and match it up at the hardware store
john5.7 87Iroc
May 17, 2001 01:13 PM
