Power Valves
Old Mar 14, 2018 | 07:41 PM
racprops's Avatar
Power Valves
Does anyone remember or know about Floating intake power valves??
These have been patented a few times, the concept is a floating valve behind the stock valve that is close by the beginning of compression and give a much higher power cycle in lower RPMs.
Makes your motor a torque monster.
There was a shop in Vegas making them.
I lost his contact info.
Rich
Old Apr 26, 2018 | 10:03 AM
83 Gman's Avatar
Re: Power Valves
How does a power valve make a "Torque Monster" ?
Old Apr 26, 2018 | 11:23 AM
racprops's Avatar
Re: Power Valves
My understanding it makes your engine act like a LOW RPM cam is in it, by closing the intake valve very early the cylinder starts to building compression much sooner than it would with a normal cam.
BUT at higher RPMs and faster valve speeds it then allows your stock cam timing to dominate the valves events.
It is a pressure controlled variable valve/cam setup. At low RPMs the beginning of pressure right after bottom dead center closes the intake automatically.
That is the clams anyway.
I also wonder how long these will last.
But I would be interested it trying it.
Torque IS what gets you down the road, so more torque at a lower RPM can allow a car to cruse at lower RPMs and thus save fuel.
Again that is the idea.
Rich
QwkTrip
Mar 30, 2026 08:49 AM
4mul8r
Oct 11, 2018 08:44 AM
JamesC
Carburetors
34
Jun 17, 2018 08:04 PM
Ztbird
Oct 2, 2016 02:28 PM
hub91z28
Sep 14, 2016 03:06 PM
