1987 Camaro, help with ignition coil
Hi,
since a few weeks I'm a proud owner of a '87 Z28 convertible. I already found invaluable information here at thirdgen.org... I love it! But right now I'm stuck:
It is/was the LG4 option, but the previous owner switched from the orig. electr. Carb to mech. Carb and old style distributor.
I want to bring it back to original. I already purchased the E4ME Carb, ECM, and distributor. I think the last thing I need is the ignition coil?!
But I cannot find information about which coil I need, how it looks, where it is mounted, how it is mounted and how it is wired. I hope somebody can help with some photos!
Thanks!
Thanks!
Re: 1987 Camaro, help with ignition coil
Thanks for your fast response.
Yes, I think I ordered the right distributor, the one with remote coil.
But where is the coil mounted, and how? Which brackets do I need? I found a image from a TPI: there, the coil is mounted very close to the distributor, on the passenger side.
But on my engine, I have absolutely no space for mounting it there. Too many hoses and wires are routed through this area... so there must be another place, where the coil is mounted.... but where?
It uses the same bracket as TBI if I remember correctly. Puts a tab on each side of the coil for bolts. Mounts on the intake between carb and dist.
Kinda like this, iirc...
I just took a look under the hood. I've found a little space and unused threads on the intake, between the distributor and the carb (like you said), a little on the drivers side... I think this is it! I'll search for the bracket, but it should be easy, make a self made one.
Thaaaaaanks!
Thaaaaaanks!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
@Tuned Performance and TY92z
Thanks for your offers, but I'm from germany, I think shipping will be 2 weeks and another 25$ ?!
I'll try it here in germany first, if I won't found it, I'll get back to you!
jfox55
Apr 8, 2002 05:49 PM
and good luck!
