750 demon 0r 850? race or regular?
Old Jan 12, 2002 | 09:26 AM
moore82nd's Avatar
Im trying to figure out the best demon carb for my engine im building i dont have much exp. with demon's and im wondering what would be best for my engine that i listed below
355
142 weind supercharger 8 pounds of boost 6 for street
23 degree trick flow heads intake flows 256 exh 186
cam int:234 exh:244 at 50 int:lift 488 exh:510
21 cc dcup forged pistons h beam connecting rods
headers with 3 inch exhaust
msd 6 ingition with supercoil
holley blue fuel pump
Also does any one know where i can get a good free desktop dyno or if your good at guessing post what you think this engine will make
Old Jan 12, 2002 | 01:43 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I would recommend the Speed Demon 750 with mechanical secondaries.
Old Jan 12, 2002 | 02:43 PM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
I am running a 750 Demon on my 408. I am not a demon expert but I have been told that Demon carbs are tested with a wet flow process, where Holley uses a dry, flow. I am not exactly sure what it means but I am assuming it is amount of air flow with a fuel flowing through it,i.e. wet flow, Dry flow is just air flowing through it, no fuel. IF I AM WRONG PLEASE CORRECT ME. Thus a 750 demon will dry flow close to 800.
Hopefully I have helped.
John
Old Jan 12, 2002 | 03:51 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
A 750 Demon dry flows 810 to be exact according to Demon when I asked this same question after hearing of this when I bought my Demon.You are correct.
Old Jan 12, 2002 | 06:29 PM
moore82nd's Avatar
whats the difference between a race demon and a speed demon carb is it worth the extra $300?
Old Jan 13, 2002 | 05:01 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
A Race Demon has removable venturi's (to change CFM ratings of the carb),different boosters more suited to racing(obviously),I beleive-no power valve which will kill any fuel economy on the street,among many other features.For what you are after I would recommend the Speed Demon 750 still,you will not need a Race Demon even with your planned combo,it would be overkill,and the $300 extra dollars will be better spent elsewhere on the car.
Old Jan 13, 2002 | 05:15 PM
Jester's Avatar
Demon just rates thier carbs differently so they can say that a "750" Demon outperforms a Holley 750. Just cheating in the name of on paper advertising. Demon is still a good carb and all..but that gets on my nerves. In practice when choosing a carb..it doesn't make that big a difference. The extra 5% or so flow just isn't that significant.
To answer the original question, either one would probably work quite well. I'd get an 850 to be safe...that engine will move some air.
PurelyPMD
May 5, 2016 04:57 PM
theurge
Aug 21, 2015 12:46 PM
85 Berl
Carburetors
Sep 26, 2001 10:57 PM
crazeinc
Jan 27, 2001 12:24 PM
