Check engine light on after mods?
Old Apr 24, 2020 | 09:38 PM
82Firebird5.0's Avatar
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
Axle/Gears: 2.73 open diff
Ok guys I’ve got a mild cam, edelbrock air cleaner, hooker headers and y pipe, advanced cam timing etc
so I extended the factory wiring harness to get the 02 sensor to fit my headers so it’s not an 02 problem. All the vacuum lines not in use are capped off. Any idea what could be causing the light? Which emissions thing should I plug back in to get it to turn off
Old Apr 24, 2020 | 09:43 PM
Re: Check engine light on after mods?
What are the codes?
Old Apr 24, 2020 | 10:12 PM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
What are the codes?
it’s an 82 car with a carb does it even have a port?
Old Apr 24, 2020 | 10:32 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Ccc has a aldl jumper it
Old Apr 24, 2020 | 11:22 PM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
It has what? I’m not sure I understand
Old Apr 25, 2020 | 07:58 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
It's the Assembly Line Diagnostic Link, used to read possible trouble codes stored in the car's computer. Here's how to retrieve and decode them:
https://www.freeautomechanic.com/dia...blecodes5.html
The information you receive will then provide you with one or more directions in which to start troubleshooting.
Old Apr 25, 2020 | 08:10 AM
Engine: Lb9
Transmission: M20
Or this
https://check-engine-light-codes.blo...-self.html?m=1
Old Apr 25, 2020 | 08:11 AM
OrangeBird's Avatar
Car: 1989 Firebird
Your original "CCC" (Computer Controlled Carb) for 1982 was , of course , controlled by an ECM (Electronic Control Module) . The way you access the ECM is through the "ALDL" (Assembly Line Diagnostic Link) . This is a connector located under the dashboard , pretty much just in front of your right knee when sitting in the driver's seat . You jump the top two righthand connectors with a paperclip (Yes , really , if you search "paperclip" here you'll find literally dozens of threads discussing it) , turn the key to the run position (do NOT start the engine) and the check engine light will begin to blink the codes . It will start by blinking code 12 three times in a row (One blink , pause , two blinks , which then repeats three times) and then after three code 12 blinks it will blink the actual stored trouble codes (For instance three blinks , pause , two blinks , repeating three times , this will be code 32) . Once all stored codes are blinked , it will return to blinking code 12 as a signal that all trouble codes have been reported , then it'll start in again with the codes , repeating this sequence till you shut off the key (and of course remove the jumper) .
PS , if your car has an electric radiator cooling fan (rather than a mechanical one bolted to the front of the waterpump , I can't recall if 1982 was electric or mechanical) don't be surprised that the ECM runs the fan in code display mode , this is totally normal .....
Old Apr 25, 2020 | 08:13 AM
OrangeBird's Avatar
Car: 1989 Firebird
Wow , both Ironwill and Tuned performance beat me to the post while I was typing , Man I must type pretty slow
Old Apr 25, 2020 | 09:21 AM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
thanks I’ll check it out and report back
Old Apr 25, 2020 | 10:04 PM
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
ok so my dumb self forgot the paper clip was in the port and started the car twice and it quit both times with a pop sound whenever I applied throttle, I was sitting there thinking about what couldn’t happened and the check engine light started flashing the codes. I felt so dumb I forgot it there. I pulled it out and the car started right up. Did I damage anything by trying to start it?
Old Apr 26, 2020 | 09:46 AM
No. Should be fine.
camaroyoungster
Oct 20, 2012 09:03 PM
chevydrvr
Feb 2, 2011 02:10 AM
Jacka1L
Sep 25, 2004 08:24 AM
