I can’t find 02 sensor plugin
Old Apr 25, 2020 | 02:16 PM
82Firebird5.0's Avatar
Car: 1982 Firebird
Engine: 5.0 LG4
Transmission: 200C
Axle/Gears: 2.73 open diff
So apparently I plugged the ECM wire into the 02 sensor when it should’ve went to the power wire on the battery? So I can’t find the plugin for the 02 sensor it’s driving me nuts please help
Old Apr 25, 2020 | 02:39 PM
Re: I can’t find 02 sensor plugin
Driver's side, over the valve cover, purple wire
I guess you've probably figured out by now, the ECM harness is ENTIRELY separate from all of the rest of the wiring; comes out of the pass side fender by the blower motor, and branches off from there. Much too eeeeezy. Any time you're looking for an ECM wire, all you have to do is start at that "trunk" and trace all the "branches" and "twigs" until you find the one you want.
anomolee
Jun 19, 2009 11:11 PM
Bazookajoe254
May 7, 2007 05:44 PM
Brandon2350
Jun 28, 2006 09:19 PM
jrosbor
Mar 1, 2006 12:16 PM
MillerTime21
Carburetors
Feb 16, 2006 04:35 PM
