Will the carb running lean cause bad gas mileage?
Old Jan 15, 2002 | 11:04 PM
Golden80's Avatar
The carb was running lean and I raised the float and everythings running a lot smoother. Haven't had a chance to check my MPG's but I was getting about 14mpg before this. Is a lean condition a main cause of bad mileage? Or will my MPG be worse since I raised the float?
Thanks,
Matt
Old Jan 16, 2002 | 01:09 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Its hard to say. A lean condition usually will make mpg better but sacrifices power and driveability also burns plugs and valves. But a lean condition could make economy worse due to more throttle useage to get up and go.
SSC
BTW nice vett
Old Jan 16, 2002 | 05:29 PM
Golden80's Avatar
[quote]BTW nice vett [quote]
Thanks! I hang out here because I'm a big Camaro fan too. And also I have a LG4 in my Vette since it's a California 80 and the people around here have a lot more experience with the LG4 than the Vette guys.
That worries me though that the mileage should get better running lean. I raised the float in my carb and my hesitation went away along with the smoke pouring out of the tailpipes. Another problem I found was I had put the needle on backwards on the float too. I haven't had a change to check MPG's yet but will on the next fillup.
Thanks,
Matt
Old Jan 16, 2002 | 07:40 PM
82camaro's Avatar
Car: 82 camaro SC
If the needle was in backwards you were running too rich--explains the smoke, poor mileage, and hesitation.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Jae992
Aug 27, 2015 09:07 AM
InfinityShade
Aug 22, 2015 08:00 PM
86IROC112
Aug 17, 2015 02:00 PM
Bradsaundry
Aug 12, 2015 12:34 AM
