Electric choke install question
Old Feb 26, 2021 | 08:12 PM
zrafferty's Avatar
I have a edelbrock 1406 got car with manual clock.
I know manual will hive better mpg cause it can be turned off.
I am reinstalling electronic choke and was thinking of wiring coke into my head light or a separate switch to enable or disable when needed.
my question is will it work or cause issues.
Old Feb 26, 2021 | 08:26 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Electric choke install question
Sounds pretty silly. Why would you ever want to disable a electric choke? Without power applied, it will never open and the engine will run rich if at all...
Old Feb 27, 2021 | 08:54 AM
zrafferty's Avatar
that kinda why I was asking if it possible and if it would cause an issue
only reason I would want to would be increase of mpg.
rather suffer lower mpg than a hole inside a piston or crack
Old Feb 27, 2021 | 09:56 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
The electric choke needs to be connected to a keyed source that will supply 12 volts whenever the ignition is on. A properly wired and adjusted choke will provide the best mileage.
Old Feb 28, 2021 | 03:20 PM
zrafferty's Avatar
I know the proper way was a idea thought I was sure about.
this is on a temp motor planning on doing a 5.3 swap efi from this carbed sbc 350
Old Mar 1, 2021 | 01:53 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
If you dont understand the workings of a carburetor choke you should NOT attempt to install an LS engine. Maybe pay someone to do that for you.
Old Mar 3, 2021 | 11:56 PM
zrafferty's Avatar
I didn't get chance to fully grow up with carbs so keeping it to try and learn.
I have done motor replacement before and only been on efi systems.
I pay other for tuning or use stock flashes
Toxicant
Carburetors
Feb 8, 2013 09:18 AM
MitchellDeMoor
Carburetors
Jul 13, 2009 11:26 AM
bigbird89
Carburetors
Nov 25, 2008 11:51 AM
matt_82transam
Carburetors
Dec 29, 2003 12:29 AM
dunerida82
Carburetors
Oct 13, 2002 06:13 PM
