800 double pumper...on 305
Old Mar 29, 2021 | 01:39 PM
1988transam's Avatar
Soo had a bad idea😂 I’m gonna put this holley double pumper 800cfm on my 305ho just to see how this goes I’ll let you guys know how it goes
Old Mar 29, 2021 | 01:55 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 800 double pumper...on 305
Seems like a waste of time and money have fun
Old Mar 29, 2021 | 06:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
If you tune it right, it will work. Not ideal, but it will work. Don't expect to make power
Old Mar 29, 2021 | 07:52 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Can it be tuned to run on the 305? ? Yes. Will is make as much power as a 600cfm carb? No.
Will it suck fuel like there's no tomorrow? Absolutely...
Old Mar 29, 2021 | 09:33 PM
No I’m not actually gonna run it I have a 600 on it I was just gonna do it for fun on the weekend lol see if it sounds different or responds differently
Old Mar 29, 2021 | 09:44 PM
NoEmissions84TA's Avatar
Carry a fire extinguisher in your car when you take it for a test drive. You never know...……...
Old Mar 29, 2021 | 10:07 PM
Lol ya good idea my grandfather back in 72 or 73 actually ran a holley 1,200 cfm three barrel in a 327 Chevy in his chevelle after he blew up his 427 I can’t imagine a carburetor that big on a 327
Old Mar 30, 2021 | 01:44 AM
Like this: https://www.ebay.com/itm/33368107436...EaAgC6EALw_wcB
Three 2 barrel carbs.
Old Mar 30, 2021 | 02:09 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Carburetors need pressure drop to work. Putting an oversized carburetor on is just going to mess up fuel delivery.
Old Mar 30, 2021 | 02:18 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Years ago I helped a coworker and friend setup dual carter 450s (I believe that was the CFM rating, they were smaller than the Edelbrock 500s) which were basically the same as an Edelbrock 500/600 with thicker sleeved venturi boosters on a weiand street tunnel ram (longer divided, smaller ports) on a 305 with 601 heads and a Comp 270s cam. Was in a 39 Chevy sedan with a 700r4 and 4.10s. Later that engine was replaced with a healthy 406 and the carbs replaced by dual GM 350 TBI units. 700r4 was replaced by a 95 4L60E. Those dual 450s worked very nicely on that hot little 305 as they are hard to over carb with the counterweighted secondary air valves, had to really spin that little 305 to get all 8 barrels open.
Old Mar 30, 2021 | 02:24 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
800cfm would be fine at higher rpm and WOT especially if it has annular boosters, its the part-throttle and transients that will be hell to tune. Also one should not expect to be able to simply floor the throttle south of 3,500-4,000 rpm without a massive bog.
Years ago I played with a Predator street carb on a mostly stock 305. It ran very well, better than I expected actually with its variable venturi. In the end a quadrajet got a little better mileage and had better off-idle performance but I would take a predator over a holley or edelbrock. Like the Q-Jet the Predator only flows the CFM that is needed and is almost impossible to overcarb an engine with.
GnawgaHyde
Feb 4, 2012 02:00 PM
mw66nova
Feb 7, 2006 03:38 PM
Nebu
Carburetors
36
Jan 12, 2005 02:21 PM
Skatepunk60
Carburetors
Apr 29, 2004 10:28 PM
jbird91
May 15, 2003 01:28 AM
