305 With Quadra Jet Needs someting more
Old Feb 3, 2012 | 08:19 AM
GnawgaHyde's Avatar
Car: 1984 Z28
Transmission: 5 speed
Axle/Gears: Stock
Ok I have the 305 with the Quadra jet.. I dont like it. I had a bad experience with quadra jets in the past and I want to get away from this one. What would you guys suggest. I want a better response.
I also have the 5 speed withthe 373 rear end. i want to put a posi in there.. again what suggestions do you have.
Old Feb 3, 2012 | 08:29 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 With Quadra Jet Needs someting more
Holley Double Pumper
Old Feb 3, 2012 | 08:32 AM
GnawgaHyde's Avatar
Car: 1984 Z28
Axle/Gears: Stock
Well Holley was a given. I just did not know if I should change over the intake as well and what model "Size" Holley to drop on.
Old Feb 3, 2012 | 08:37 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can't put a squarebore Holley on a stock spreadbore manifold.
You also need to change the distributor at the same time.
Old Feb 4, 2012 | 09:03 AM
Fionnla's Avatar
Car: 85 Camaro S/C
Engine: 350 Vortec 330 HP 650 Demon Carb
Axle/Gears: 3.42 Richmond Powertrax
Holley makes a 650 cfm that is a replacement for the quadrajet. Model #4175 has vac sec., with electric choke and is the stock replacement. Model #4165 has mechanical sec., and manual choke. Sold by Summit and others.
Old Feb 4, 2012 | 09:06 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Stay away from Vac secondaries with a manual
Old Feb 4, 2012 | 09:18 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Those are smog replacement carbs for 70s pickups and vans.
Old Feb 4, 2012 | 10:48 AM
Fionnla's Avatar
Car: 85 Camaro S/C
You are correct sir, those Holley's won't work on 84 305 because of computer controlled carb & Distributor. There is a Quadrajet that is remanufactored by Holley that is a replacement for his old stock one. It's pt#64-70087. Cost $400+. Sorry about the wrong info on the Holley's.
Old Feb 4, 2012 | 10:53 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They'll work if you replace the distributor and you don't care about emissions legality. They're just not especially performance-oriented.
Old Feb 4, 2012 | 02:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
So, you had a bad experience with a q-jet in the past. What does that have to do with this one?
Only reason I'll echo Apeiron's recommendation is you have a T5. Get a Performer intake and a 600 Holley double pumper. And a vacuum/mechanical advance distributor, as mentioned.
Then $700 later, you'll know the q-jet isn't what's holding back performance with your 305.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
