Can't adjust pressure on 4309...
1 Post
Car: 86 IROC
Engine: 355
Transmission: WC 5spd
Axle/Gears: 3.24
Gents,
Finally getting back to my beast!!! For you young fella's, enjoy all that free time....life gets in the way big time.
Having some issues with my 4309; fuel pressure will not adjust no matter what I do with the screw....worn out diaphragm? I took it apart and nothing looks broken.
Buy another one or is there a better recommendation for a TPI to carb application?
Thanks,
Faz
Thanks,
Faz
1 Post
Car: 86 IROC
Engine: 355
Axle/Gears: 3.24
Re: Can't adjust pressure on 4309...
...some more observations...
I unhooked the line to the carb and the return; even with the adjustment screw completely removed, gas shoots out of the out port at alarming rate and nothing out of the return.
So, it's not regulating at all. I set out to buy a replacement....$220!!! They have gone up.
Holley 12-887 seems a better priced alternate: https://www.holley.com/products/fuel...s/parts/12-887
Fuel pump was replaced with the following:
Am I missing anything obvious? All feedback appreciated.
I am having the same problem at the moment. I was running the stock intank TPI pump with the 4309 and Holley 750 Street HP carb. I had no problems keeping it at 6 psi. My pump went bad after setting for a while and I replaced it with GM EP381 which is a TBI pump. Now with the same setup, I cant get the fuel pressure to adjust. I purchased a rebuild kit for the 4309 and installed it with the same problem. I am currently trying to clean out the stock return line and make sure it is not blocked.
Was thinking of going with the same holley regulator you linked.
I tested the fpr with a pressure tester and with the adjuster screw completely out, I still got 6 psi. I may try running the return directly to a gas jug to rule out the return line.
Here is the link to the rebuild kit.
Mallory 29859 rebuild kit for 4309 FPR
1 Post
Car: 86 IROC
Engine: 355
Axle/Gears: 3.24
Looks like there’s blockage in the return line right at the pump….thankfully I cut the inspection hatch. I’ll take the pump out to see what’s going on….
