Fuel return line question.
Old Jul 3, 2023 | 07:58 PM
Wallus's Avatar
Hey folks. I'm installing a 350 in place of a 305 in an 83 Camaro. The car of course has a fuel return line but the fuel pump that came on the 350 only has in and out lines. Can I just plug the return line without causing a headache or should I shell out for a correct pump? Also, all of the EVAP junk is leaving the building lol. Can I plug the line coming from the tank? If I can will I have to use a vented gas cap?
Thanks for any help, Wally.
Upon further research, I see that the electric pump supplies from 9 to13 psi on some Camaro's. Is it the same pressure from the electric pumps that feed the mechanical pump or are they a lower pressure? Since this 350 is carbureted then the carb will likely flood with the higher pressure electric pump. Can I remove the tank pump and put an extension on the sending unit and just use the mechanical pump or do I need a separate regulator with a return line?
Thank you, Wally
Old Jul 3, 2023 | 08:10 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Fuel return line question.
Get the correct pump...
Old Jul 5, 2023 | 10:04 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Why not get the correct pump and use the factory system? Also the EVAP is fine reduce gas smells
T.L.
Carburetors
Nov 10, 2021 03:04 PM
Black_TA
Carburetors
Apr 19, 2012 12:54 PM
MTCAMARO
Carburetors
Mar 11, 2010 10:34 AM
82flamedZ
Carburetors
Jan 17, 2006 02:00 PM
zapr
Apr 25, 2005 06:46 PM
