Drainig fuel without dropping the tank?
Old Sep 25, 2025 | 01:33 PM
Curvewrecker's Avatar
I have an 89 V6 Bird with a tank full of 10 year old fuel. Can I siphon it easily, and are there any tips you might suggest?
Old Sep 25, 2025 | 01:49 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
Re: Drainig fuel without dropping the tank?
12v electric fuel transfer pump kit. There are a lot of options on Amazon for them. You could also get the hand pump style and some hose.
Old Sep 25, 2025 | 02:25 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
I used a harbor freight manual fuel pump. I couldn’t get the last few gallons out. The baffles make it quite difficult.
Old Sep 25, 2025 | 02:39 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
I used a hand-pump and pulled the fuel from the fuel line connection at the tank...
Old Sep 28, 2025 | 06:23 PM
I bought a $10 12v pump off AMZ and will try pulling from the fuel line connection at the tank. Thanks for the great replies.
Old Oct 4, 2025 | 03:35 PM
My 12v pump was able to suck maybe two gallons from the filler neck. I wasn't able to get any fuel to flow through the old fuel filter. I used a hose barb attached to the filter and got nothing out that way. I'm still working on it.
Old Oct 4, 2025 | 04:16 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Detach the hose somewhere in the back and drain into gas cans. Jump the fuel pump relay to pump out fuel. Do it outdoors and don't be under the vehicle or anywhere near that gas can when you turn on the pump. Don't need to become burn victim.
Old Oct 4, 2025 | 05:38 PM
T.L.'s Avatar
Yeah, you don't suck it out from the filler neck. You suck it out from the fuel line connection underneath the car...
Old Oct 4, 2025 | 05:59 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
If the factory fuelpump works, you can unhook the fuel filter, put rubber line on pipe into gas can and jump the relay to kick on the pump
Old Oct 4, 2025 | 07:36 PM
Originally Posted by TTOP350
If the factory fuel pump works, you can unhook the fuel filter, put rubber line on pipe into gas can and jump the relay to kick on the pump
We attempted this today. Apparently it has a dead fuel pump. I have repaired lots of chewed up wiring so far, so its unclear if it a pump or wiring issue at this point.
It looks like we are dropping the tank on Tuesday.
Old Oct 7, 2025 | 02:29 PM
StevenK's Avatar
Car: 91 Z28
You do if you have a dead pump. The metal lines coming off the top of the tank are not easy to get a pump on unless you cut them. and then you are now pulling through a motor and a possibly full of junk filter sock.
You can do it from the filler neck pretty easily. Not 100% comes out, but it sure makes it lighter when you are pulling it out from the car above your head
Old Oct 7, 2025 | 08:45 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Originally Posted by Curvewrecker
I have an 89 V6 Bird with a tank full of 10 year old fuel?
sometimes its easier in the long run to replace the fuel tank
Old Oct 19, 2025 | 05:32 PM
I finally dropped the tank today and it was a complete mess. I'm replacing the tank and fuel pump assembly entirely. Pics to follow. Thanks for all the replies.
Old Oct 19, 2025 | 06:14 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Delphi still makes the complete fuel pump module assembly for fuel injected V6 3rd gen F-body cars. They don't make one anymore for V8 or carbureted cars
DELPHI HP10266 | Fuel Pump Module Assembly| 1985 to 1989 2.8L V6 & 1990 to 1992 3.1L V6 | F-body Camaro & Firebird | Rock Auto
These are on Wholesaler Closeout for $73.79.
Old Oct 23, 2025 | 07:08 PM
the tank and pump are nasty. what are the chances the injectors are any good?
Old Oct 23, 2025 | 07:29 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
New regulator and injectors will be needed. Contact @southbay08
Old Oct 23, 2025 | 08:21 PM
southbay's Avatar
Hey...we have the regulator and any injectors you need. You can go to our website under the tpi category or just give us a call at the shop. We'll be more than happy to help you.
you will also receive 10% off for being a
thirdgen member. Promo code is tg11
Old Oct 23, 2025 | 08:27 PM
Engine: Lb9
Transmission: M20
https://www.southbayfuelinjectors.co...-1992-tpi.html
Old Oct 26, 2025 | 06:03 PM
The new tank and fuel pump got it going. Thanks for all the help guys. I'll do injectors next.
Old Oct 26, 2025 | 06:50 PM
Airwolfe's Avatar
Did you end up getting that Delphi fuel pump module assembly I linked from Rock Auto?
Old Oct 26, 2025 | 07:33 PM
I did get the Delphi. Thanks.
Old Oct 26, 2025 | 08:10 PM
Airwolfe's Avatar
Did it seem like a quality sending unit and hanger assembly? Is the pump quiet?
Old Oct 26, 2025 | 08:14 PM
The pump is silent. The fit was almost exact, an extra inch or two of rubber line was all that was needed. I had no other issues.
thatsupnow
Mar 29, 2022 07:55 PM
BrianChevy
Apr 19, 2014 07:59 PM
elthomas
Aug 14, 2008 12:57 AM
WOODY
Sep 18, 2000 07:20 PM
