my Q jet is leaking????
Old Feb 10, 2002 | 01:20 AM
fattie92's Avatar
ok, we finaly got a nice day here so i got to clean my car...after i washed it, i desided to spray the carb with some cleaner,, i noticed that the carb cleaner was leakin out of the botton of the carb and pooling on the intake manifold....im HOPING its just a bad gasket.,,,and hopefully everyone will agree with me,, i just cant afford a new carb at the moment
any help guys?? thanks alot!
Old Feb 10, 2002 | 05:00 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
are you sure its comming from the gasket? It sounds like alot of fuel to be doing so. I would check the filter housing to make sure it not cracked and the threads on the fuel line to see if something got cross threaded durring the last filter change. Other than that the float could be stuck but the fuel will tend to pour out of the top of the carb.
Good Luck!
Old Feb 10, 2002 | 09:05 PM
fattie92's Avatar
the fuel line is on the other side.. i noticed it leaking on the drivers side near the back of the carb right under the linkage. im HOPEING its the gasket...but like you basilcy siad... i dont know how the hell a little spray would leak like it was...i though the filter was on the front passanger side of the carb, along with the fuel line. so what should i do now?? or look for?i havent looked while it was running to see if gas is coming out yet, but id think id see smoke coming out of the cowl induction if that were the case..maybe im wrong and it would evaporate before it got there though...but my gas doenst seem to be going down, actualy im getting really good mpg at the moment......HELP!!
Old Feb 11, 2002 | 08:51 PM
GRENDLE's Avatar
you can get a jiffy kit rebuild kit for like $20 , sounds like one or more of the gaskets were going and you helped them by cleaning it. not a big deal, q-jets are pretty simple to rebuild, a book helps because the instructions that come with the kit are junk. any camaro/ta manual should have what your looking for, try a second gen book also, there are a lot of different q-jets, just make sure you get a book with your carb. after the rebuild , i'm sure most here would be happy to help with some performance hop ups and common problem solvers. if there's a pic your part near you the tuning possibilities are almost endless and cheap.
Old Feb 11, 2002 | 10:22 PM
fattie92's Avatar
where can i get that kit?? and how long will that take to do? its kinda of a daily driver, but i am putting in a new engine, so that will be the only time ill have to do it.
Old Feb 12, 2002 | 09:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I assume you were spraying the cleaner inside the carb, without the engine running. I believe you said it was leaking cleaner, not gas.
If the above are true, then what probably happened is some of the cleaner leaked past the secondary throttle shaft. That isn't anything to get excited about.
Old Feb 12, 2002 | 09:23 PM
fattie92's Avatar
yeah the car was off and i was sprayin the walls of the secondaries...but how would it get outside the carb?
Old Feb 13, 2002 | 01:29 PM
five7kid's Avatar
In order for the throttle shaft to turn in the throttle plate, there has to be some clearance between the shaft and the holes through which it goes. Normally, this allows a little vacuum leakage past the shafts, but not enough to be of concern. Also normally, if subjected to sufficient liquid, it will also wick through that clearance (especially carb cleaner).
Excessive wear between the throttle shaft and plate would be a problem, though. But, typically that doesn't occur on the secondaries of a q-jet. To check, open the trottle so the secondaries are open about half way, then hold it there and grab the secondary shaft from the outside. Wiggle it in all directions. If you can see movement, you've go wear. If not, don't worry about it.
Old Feb 13, 2002 | 01:48 PM
fattie92's Avatar
ok ill try this,, thanks 4 your help
RS Reaper
Oct 17, 2018 07:52 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
