what air cleaner will fit?
Old Feb 21, 2002 | 01:15 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
ok, here's what i have
305, Edelbrock performer intake(not performer RPM), and a 750CFM Carter carb. I am curious what is the largest air cleaner i can run since a 14x3 drop base did not seem to want to fit.....since the fuel goes in higher up on the carb than on a holley. Anyone ever gotten anything bigger to fit than the 12x1.5 i have now? Also i have the iroc hood with louvers, not like it should matter though.
thanks
steve
Old Feb 24, 2002 | 06:48 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Surprised nobody's responded yet.
I'm a little surprised the 14x3 drop doesn't fit. If the 12" does, perhaps get a taller element (with a longer stud, of course).
I'd be even more surprised if a dual-snorkel doesn't fit.
(Man, I'm just full of surprises tonight...)
Old Feb 25, 2002 | 01:07 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
A 14x3 fits! It sounds to me like you need a carb to air cleaner spacer probably a 1/2in. They have them in the performance sections of most parts stores, its a little plastic ring. If you wanted something that flows more air, a standard 14x3 non drop fits your combo also and will clear you carter linkage. Ive got a non drop base on the firebird 14x3 and it sticks up about a 1/8 of an inch above the firewall. If you go with a non drop base get a flat lid (top) setup and you will have no problems.
Old Feb 25, 2002 | 02:31 PM
xpndbl3's Avatar
Car: 1984 Z28
hey guys,
thanks for the advice....yea i will have to try out different combos and see what works, i was hoping i could fit a 14x3 on there.
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
