gettin cold air in the engine
Old Mar 11, 2002 | 12:26 AM
82T/A powah's Avatar
i was reading a message that someone posted earlyer on about how an open element airfilter, say my 14" one is not doin it's full job if you dont have a cowl hood or something to get fresh air in..now i do have a stock cowl hood on my 82 TA but non functional, just the scope by the windshield is covered over by a piece of plastic.. should i just go ahead and remove that, or will water and **** be bad to get in there say when it rains? i also have the extreme air top on the filter so that could draw good air in from the top.. any ideas on what i should do, because i assume my losing horsepower by having hot air circulating in the engine bay right? probably quite a bit of HP..
any ideas would be great
thanks
Old Mar 11, 2002 | 06:39 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Your not really going to see any huge power gain from going cold air/ram air from open elemnt. I have a 14" open element in my car now and I'm working on a way to make my hood (see sig) scoops functional by installing a stock air cleaner with foam on top to seal the cleaner against the hood. It's also going to have a baffle to collect water from the open scoops and drain them properly beneth the engine. Also I'm leaving the stock inlet open so I can put the caps on the scoops if I'm driving through a thunderstorm or carwash. I'm assuming you could do the same with your 'bird. This wouldent look sloppy like all the other "ram-air/ CAI" systems that have tubes running every which way, if you care how your bay looks like I do .
You will notice some performance, mostly upper-end throttle responce and a little more power up top. Dont expect 25 hp or anything.
-Matt
Old Mar 15, 2002 | 11:17 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey flash wut edelbrock intake did u use? the performer or performer rpm? i am lookin for a manifold that will fit unde rmy stock formula hood with a holley and a 14x3 element on it. thanks
kyle5647
Aug 15, 2015 11:56 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Tonyy_z
Aug 12, 2015 07:20 AM
