Online Poll
Car: Take
Engine: Your
Transmission: Pick
Online Poll
I am researching what mods work, and what mods don't. If you get a chance, please take my online poll. Online Poll
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
TB Coolant Bypass,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
Some mods produce a qualitative change and it's hard to guess HP, ET, or some other change. Maybe you could put in a "Comment Box".
A good example, in my case, was knocking out the anti-tamper plugs in my electronic Q-Jet and fine tuning the air bleed, solenoid needle travel, idle mixture, TPS, and secondary rods. The engine feels a LOT better but I couldn't tell you what HP I gained. Also, I replaced the single stock muffler with an Edelbrock RPM Series muffler. The car definitely feels better from 1500-3000 RPMs but I don't have any quantitative measure to prove it.
Yeah, comments section would be nice. So would a breakdown between the 305 4bbl LG-4 and the 305 4bbl L-69 HO. Almost anything you do to the LG-4 makes it go faster. Not so with the L-69 HO motor.
