I need help with my carb!
Old Nov 17, 2000 | 11:05 PM
BBis23's Avatar
I have an 87 Firebird Formula. My choke light constantly stays on at all times. When I turn the car off it continues to diesel for a long time. I just got a tune-up and the car would stall so I adjusted the timing higher so it would not stall. What should I do about this problem?
Old Nov 18, 2000 | 12:06 AM
mtx28's Avatar
omg, how annoying is that !?! my car does it to... but, do you have a manual? if so, and you shut it off even when you only let the wheels rotate half a turn or so, with the clutch in, it will do that. but yea, good luck fixing it, sorry i cant help
Old Nov 18, 2000 | 12:14 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Sounds like the choke thermostat is bad/disconnected.
Does the choke open when the car is warm??
Does it idle higher than normal??
Seem to be running rich??
All the symptoms you stated could be part of the choke problem.
I would make sure its hooked up and you have 12v at the choke coil before replacing it.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Nov 25, 2000 | 06:10 PM
gbledsoe's Avatar
I have an '87 carborated camaro with an electric choke. There is 12v at the choke coil connector, but when ever a load is placed on it (connecting it the choke coil) the voltage drops next to nil. I had a mechanic at a local dealer tell me he's seen once in while this condition, caused be the choke power being disrupted at the oil sending unit. My question is, "Where does the power come from that supplies the choke? I know it's keyed (12v when ignition is on), but where is the source and what components does it supply?
--GBledsoe
Old Nov 25, 2000 | 06:11 PM
gbledsoe's Avatar
On my '87 camaro, the choke light only illuminates with starting the car. When should it come on, if at all? What triggers it to come on?
--GBledsoe
Old Nov 25, 2000 | 08:31 PM
Biochem's Avatar
Car: 2002 SOM z28
My choke light stays on when ever I ground that stinking wire on the manifold... Check the fuse under the dash. Mine also makes this annoying eeeeeeeehehhhhhhh sound too...
Don;t know if that is your problem, but worth a check. If it isn't working right (ie- staying closed) it could cause it to stay closed and be over rich, then it might desel.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Old Nov 26, 2000 | 10:28 PM
84FBODY's Avatar
For y'alls info the CHOKE light is also your electrical short light. if, while the car is running, that light is on it means you have a dead short usually at the alternator. The light is suppose to come on when you have the key on then when you start the car it will turn off. Unless it's broke.
John Chamberlain
1984 Sport Coupe Camaro, 1979 350. Dynomax 2 3/4" cat back single in dual out muffler. Have Heads, Weiand Stealth intake, IN process of rebuild on 350 (355 all that good jazz) saving for Transmission THEN PAINT!
The Allmighty Warrior Court Jester of The Not-So-Famous Cascade Crew
[This message has been edited by 84FBODY (edited November 26, 2000).]
Old Nov 28, 2000 | 09:59 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
I recently had a S10 that had the same problem. (12v with no load but nothing with the choke wire connected)
Found a bad choke relay. It was mounted on the firewall (dr. side) next to the fender.
I show a choke relay in my 86 Camaro GM manual but I don't know if its the same in a 87.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Nov 29, 2000 | 11:52 PM
gbledsoe's Avatar
In the wiring diagrams, I can't find a choke heater relay for the '87. For now, I have just wired it to a switched 12v source until I find time to trace down the problem.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
